3-Point Hitch Trailer Mover
/ 3-Point Hitch Trailer Mover
I REALLY like my King Kutter trailer mover. I would challenge anyone to find one heavier built. They make 2 models; this is the heavier one. It has clevis style hook-up (stronger) for the lower arms and comes with a chain and adjustable connector to attach to your drawbar to prevent upward movement. It also has a spot for trailer breakaway chains to connect to. I have a ball mount with a hook welded on it that I use on this trailer mover and I have pulled trees and everything using it. Highly recommend.
I might go this route. Rural King sells these with their name on it and I have a Rural King not far away.
The clevis-stype hook-up is I think to make it quick-hitch compatible? I'm actually not a fan of that since I don't have a quick-hitch; I've found on heavier implements it makes attaching more difficult. But on this, not a big deal since there's no weight to it and the whole thing can just be picked up.
Thanks for the review. :)
/ 3-Point Hitch Trailer Mover #22
I built my own multi-use hitch, had to remodel it a bit to fit the quick hitch: HPIM2960.JPG HPIM2961.JPG
/ 3-Point Hitch Trailer Mover #23
/ 3-Point Hitch Trailer Mover #24
/ 3-Point Hitch Trailer Mover #25
Just realized that I didn't show any pictures of it moving a trailer:
/ 3-Point Hitch Trailer Mover #26
Yep. The Omni Hitch has a few clever design elements that make it more of a multi tool
/ 3-Point Hitch Trailer Mover #27
To the OP, PA452, did you get a 3ph trailer mover?
We need pictures when you do.
/ 3-Point Hitch Trailer Mover #28
My 3pt trailer mover worked fine until I got pallet forks. Now I just drop a ball in the hole in the end of a fork. Just a ball is lighter than the 3pt mover. Even if it is QH compatible it's small enough i need to pick it up & put it on the hitch rather than grabbing it with the QH like normal impliments.
Get a cheap 3pt trailer mover at your local farm store if you dont use forks. Even the lightest one will be fine for a parking lot or 5mph over dirt & grass.
My record was a trailer falling off 4 times in under 400 yards. A poorly balanced tongue light tilting deck. I couldn't be bothered to get off to latch the hitch much less hook up chains. I just scooped up the hitch with the ball on the fork & kept going. I actually latch the hitch on my current trailers as I care about them. No reason for safety chains at under 5mph though unless there are other problems.
/ 3-Point Hitch Trailer Mover #29
Here's what I use. The shackle keeps the drawbar from turning. I also welded a receiver into my box blade for moving trailers around.
/ 3-Point Hitch Trailer Mover #30
I use it a lot on the front with a SSQA to 3 point adapter:
The bale spear in the Omni Transformer Hitch:
On the V417, this trailer weighs over 10,000 pounds, with just over 3,500 pounds on the hitch:
/ 3-Point Hitch Trailer Mover #32
I thought the trailer movers were over priced so I built this one for less than $50 and a couple of hours of work.
/ 3-Point Hitch Trailer Mover #33
Thatç—´ a pretty good trick. Lifting 3500 lbs with a 1500 lb rated loader.
No trick, different machine.
The Toolcat will lift just over 3000 pounds according to my crane scale.
Bobcat's skid steer ROC is half the tipping weight. The Toolcat maxes out before the rear axle comes off the ground.
The V417 is rated at 4400 pounds. I have lifted over 6000 pounds with it blue TU.gif
The V417 max lift thread: https://www.tractorbynet.com/forums...47-v417-max-lift-post3257905.html#post3257905
Transfer tank (A61567)
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
PT Gravity Wagon (A64127)
PT Gravity Wagon...
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
Steiner 450 (A64126)
