PTO Shafts
/ PTO Shafts #1
Doug62
Charleston, SC
new
Bought a Woods RD660-1 mower with a non covered PTO shaft. I'd like to remedy that situation. Can I buy the cover itself or is it best to just buy a new shaft assembly?
Best place to buy?
/ PTO Shafts #2
I would first check with your mower dealership. Do they have such a beast? Then try after market sites such as - Messicks. Give them a call - see what they can come up with.
/ PTO Shafts #3
If you revise your opening post to include mower brand and, if possible, PTO shaft brand, you will receive more useful responses. Your opening posts are consistently vague.
Tractor Supply Company inventories quite a few PTO shafts and some parts.
Problem will be finding the guard which fits your particular PTO drive shaft.
/ PTO Shafts #6
Most of the covers ride in machined grooves at the ends near the yokes. Does your shaft have those?
/ PTO Shafts #7
/ PTO Shafts #9
Bought a mower with a non covered PTO shaft. I'd like to remedy that situation. Can I buy the cover itself or is it best to just buy a new shaft assembly?
Best place to buy?
I have a Bondioli & Pavesi Series 100, size 4 PTO shaft which came with used flail mower and the cover or shield was busted pretty bad and after having spent quite bit of time in trying to figure out the correct replacement shield, I bought all new (up to 35 hp) shaft from Amazon vendor (All States Ag Parts) for $175
Oh well, I now have used spare parts for my other PTO shafts hoping they will fit if I ever need them?
The new shaft is a no-name brand and appears to be of equal quality to OEM, but only time will tell.
Old:
New:
/ PTO Shafts #11
Agri Supply is less expensive by a long shot for a generic shaft.
Yes if one is looking for cheap there is always one out there. I saw some around hundred buck or so no problem.
It would have been even cheaper just not do anything but use the Bondioli & Pavesi PTO shaft I still have!
I was looking for replacement & best value for my money - note the 35hp rating.
/ PTO Shafts #12
A farmer might, or might not, have a pto shield kicking around they might sell you.
I say "might not", only because I make my own pto shafts up because it is so much cheaper, but I do not buy the shielding for them when I build them, so i don't have any for you.
/ PTO Shafts
My mistake. It's a Woods RM660-1 Finish mower. The shaft just has a made in Italy marker but that's about all I can see so far.
/ PTO Shafts #14
Actually I bought one from Agri-Supply to refit my JD Haybine. I bent the original.. Works fine and cost less than 100 bucks, shipped.
/ PTO Shafts #15
It is incredible how cheap some of that chicom stuff is!
/ PTO Shafts
/ PTO Shafts #19
They do but good luck finding where to buy them. I’d love to. I have found one or two specific items on eBay but overall they only go through dealers and those are not always convenient to me.
Hercules Pesticide Applicator with Nozzle (A61568)
Hercules Pesticide...
2025 Heavy Duty Wheel Balancer (A61568)
2025 Heavy Duty...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61569)
2017 Load Trail...
UNUSED KJ 3PC WIRE MESH (A62131)
UNUSED KJ 3PC WIRE...
2014 Sea Ray 250SLX Bowrider Boat with T/A Boat Trailer (A61569)
2014 Sea Ray...
