Howse 10 Ft Single Spindle Rotary Cutter
/ Howse 10 Ft Single Spindle Rotary Cutter #1
Chewwy
Upstate SC, Near the Electric City
Kubota L3240, MF 265, MF383
Is anyone familiar with a 10 Ft Howse Single Spindle Rotary Cutter? Any info would be appreciated.
i have an opportunity to buy a used 10 ft House Rotary Cutter at a good price and in excellent condition. I can’t find any info on it on the Howse Website or find any manuals for it.
Howse currently makes 7’ and 8’ single spindle cutters. Their 10 ft cutter has two spindles.
/ Howse 10 Ft Single Spindle Rotary Cutter #2
Howse liquidated in bankruptcy several years ago.
Be aware you are considering an orphan.
/ Howse 10 Ft Single Spindle Rotary Cutter #3
I've never saw a 10' single spindle cutter??? Not sure anyone makes one???
In regards to Howse no longer making cutters. They bought all of their powertrain items from someone else, gearbox, driveline, etc. Would be no problem finding parts.
/ Howse 10 Ft Single Spindle Rotary Cutter #4
You can call Doug Addis, owner of Southern Farm Supply he bought up all the Howse stuff . I think they got it stored in Union Grove NC Contact | Southern Farm Supply
I've never seen a single spindle 10 footer either . Anyhow Doug and his gang should have whats left of Howse and parts overthere . Doug would know imo .
Am aware Howse went bankrupt. This machine is very heavily constructed an shows little signs of wear or abuse. It will likely outlive me, maybe several times over.
ovrszd;5817938 In regards to Howse no longer making cutters. They bought all of their powertrain items from someone else said:
Kinda what I figured. In looking at several Howse parts manuals, a lot of their parts fit several different sizes of their cutters.
/ Howse 10 Ft Single Spindle Rotary Cutter #7
Agreed. I’m not sure what kind of dealer parts you’d need for a cutter anyway. Howse made a solid piece. I wouldn’t hesitate to buy one. I’ve got a Howse finish mower that’s the heaviest duty finish mower I’ve seen.
/ Howse 10 Ft Single Spindle Rotary Cutter #8
I'd also like to see some pics of this cutter if possible?? It'll be a first for me!!!! I'm very curious about it. Also,, would it pull harder than a dual spindle 10ft cutter? That's some long blades swinging around under there!!!
/ Howse 10 Ft Single Spindle Rotary Cutter #9
I can't imagine anything on the cutter tearing up but I have to wonder what size tractor and PTO HP it requires to get it spinning. My little 4' Howse really takes a jolt to get going.
Is there any way you could hook it to the tractor you intend to use before buying it?
Eureka. Question is answered.
I went this morning and took measurements. It is only an 8 ft cutter with single spindle which makes it a Howse Model HD8D.
Sorry for my confusion.
It was advertised simply as “HOWSE ROTARY CUTTER, 10' pull type, GC.”
At only 8 ft wide it is street legal, which solves my problem on how to transport it.
/ Howse 10 Ft Single Spindle Rotary Cutter #11
Your tractor will appreciate it too!!!
8' single spindles are around in the older models. Almost all new 8' cutters are dual spindle. Usually 7' is the max for single spindle.
Should make you a great cutter!!!
/ Howse 10 Ft Single Spindle Rotary Cutter #12
On a 8 or 10ft cutter, how big are the swinging blades? They must simply destroy everything in its path.
Any idea why that is?
Economics, reliability, customer preference, etc.?
My guess is the length of the implement imposes transportation problems. Multiple spindles results in being shorter front to back and can be loaded sideways on a flatbed without being a wide load.
/ Howse 10 Ft Single Spindle Rotary Cutter #14
My guess is strength of the gearbox shaft plus, the length of the mower. The wider the mower gets, the more leverage the blades have over the gearbox shaft. At least, that's my theory.
/ Howse 10 Ft Single Spindle Rotary Cutter #15
There are two blades. Also either a bar that they fasten to or a stump jumper pan. They are usually 18" or so in length/diameter. So if you have 8ft cut, minus 18", divided by 2 = 39" blade. All estimates for the "detail" police. :)
/ Howse 10 Ft Single Spindle Rotary Cutter #16
I've always been told they pull a bit easier and as you mentioned, they are more compact.
I had a 3pt mounted 10ft dual spindle. It was very compact for it's width size.
/ Howse 10 Ft Single Spindle Rotary Cutter #17
I have a 7' Howse that I bought close to 20 years ago at a store liquidation. I'm not sure but I think the model is MH72CT2. It is Cat 2 hitch and weighs 1462 lbs. and it is way back there.
Recommended HP is 50-85. I would question if you have enough tractor for it. I used to run it on a Case 1070 (108 pto hp rated) and 10,000+ lb. tractor and it made the front light on it if I didn't have weights or the loader on it. It also used lots of Hp in heavy brush. I've only had it on my M7060 once and it handled OK but not great. I have a Landpride 12' winged mower now and I can tell you it requires much less Hp to run. I only use the Howse in places the Landpride won't fit or cutting the rough stuff I don't want the new mower in.
Thanks for your input. You could be right power wise. The recommended HP for the HD8D from the operating manual “ranges from 55 hp for light cutting in level terrain up to 80 hp in heavy cutting in rough terrain.” My plan for this cutter is all light cutting in mostly level terrain.
I’m less concerned with the weight since it is a pull type cutter attached to the drawbar, not hanging on the 3 pt hitch. If I need more front end weight I can hang a few hundred lbs on the front end. But I would really be surprised if that’s going to be needed. The Kubota M7060 weighs almost 2,000 lbs less than the MF 265 (engine is aluminum vs cast iron.)
/ Howse 10 Ft Single Spindle Rotary Cutter #19
Guess I missed the MF 265 in your Tractor info. I was thinking you were using the Kubota. Didn't realize this was a pull type mower. No wonder my manual didn't have that model. You should be good with that combination I would think.
/ Howse 10 Ft Single Spindle Rotary Cutter #20
Don't know the details but Howse has an active lineup of equipment and offers parts for older Howse equipment. Looked at some new rotary cutters just last week. Might be manufactured by someone else and Howse branded. No idea how far back legacy parts support is.
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
Hydraulic Brush Cutter Mini Skid Steer Attachment (A59228)
Hydraulic Brush...
