BWSwede
Hello,
I have run into something that I couldn't be the first to encounter so I am looking to see what others have done.
My equipment trailer has welded D rings and stake pocket D rings down each side. With one of the implement setups on my tractor I need to have 2 D rings welded to the rear frame member of the trailer to anchor the 12,500 pound tractor. The side frame of the trailer is is a very sturdy steel channel that accepts welded D rings easily. The rear frame member is a bent plate (or bent sheet metal depending on the definition) and doesn't appear thick enough to have D rings welded to it with any sort of serious load applied. Granted the rear frame does have 2 horizontal steel straps welded to the outside rear of it to support the ramps, but just looking at the thickness of the steel it seems that if I welded a D ring to the top of it and really torqued on it with my ratchet binders it seems like it would bend upward.
What have others done in this situation?
TIA,
Blane
TIA,
Blane
