Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #1
BWSwede
Washington
Yanmar
Hello,
I have run into something that I couldn't be the first to encounter so I am looking to see what others have done.
My equipment trailer has welded D rings and stake pocket D rings down each side. With one of the implement setups on my tractor I need to have 2 D rings welded to the rear frame member of the trailer to anchor the 12,500 pound tractor. The side frame of the trailer is is a very sturdy steel channel that accepts welded D rings easily. The rear frame member is a bent plate (or bent sheet metal depending on the definition) and doesn't appear thick enough to have D rings welded to it with any sort of serious load applied. Granted the rear frame does have 2 horizontal steel straps welded to the outside rear of it to support the ramps, but just looking at the thickness of the steel it seems that if I welded a D ring to the top of it and really torqued on it with my ratchet binders it seems like it would bend upward.
What have others done in this situation?
TIA,
Blane
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #2
A picture of what you are describing would help a lot. I can’t really picture what you talking about. I have had some situations where there wasn’t a good place to anchor whatever it was I was hauling and I had to put new anchor points on the machine.
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #3
My trailer is only 7000# but have encountered a similar situation. Mine is 5" channel on the side with a light angle iron on the back. I also have ramp brackets and a 1" rod as a hinge pin for the ramps where the brackets are welded to the angle iron. I've used the 1" rod as an anchor point on occasion.
For your situation if the next frame member forward would be suitable you could weld something like this to it and have a recessed anchor point.
G7 3/8" Floor Tie Down Weld On
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #4
Hello,
TIA,
Blane
You are hauling a 12,500 lb tractor on a 14K rated trailer?
Thanks for the replies guys.
I have attached two photos showing the end piece of the trailer. You can see it is a piece of steel bent in two locations to wrap around the trailer's side frame channels. The thickness of the steel is 3/16".
I have looked at adding additional attachment points to the tractor but there doesn't seem to be a good location.
3Ts - I thought about attaching something to the steel bars that support the ramps but with the angle I am pulling I was worried about bending the bar in its weak direction. I could weld additional intermediate supports between the steel bar and the rear frame of the trailer but then my ramps won't be able to hook over the bar. The link you provided is interesting but unfortunately I don't have access to next forward steel cross member under the wood as the rear implement on the tractor is a butt plate for logs and it extends within a couple inches of the back of the trailer.
fried1765- I hope it is okay to haul this heavy of tractor and implement on the trailer. I weighed the loaded truck and trailer and got 13,900 pounds on the trailer axles which I think puts about 2000 pounds on the tongue. My hitch is rated at 2400 pounds. If I am missing something please let me know.
Thanks again,
Blane
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #6
Thanks for the pictures. Can you not put the d rings right above the round clearance lights? I would maybe place them on top of the rear member at at 45 degree angle pointing towards the center of the trailer. In this location they would be directly above the heavy channel iron frame.
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #7
Maybe something like this? The green outline is a plate you could weld in to make the things level with the rear frame member. Pink would be the D ring.
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #8
Thanks again,
Blane
It would seem to be within limits, unless you add a heavier implement at some point.
If your tractor really did weigh 12,500 lbs. though, your 14K bare trailer would seem to weigh about 3,000 lbs, totaling 15,500 lbs.
What sort of truck are you using to tow with?
/ Welding D rings to rear frame member of 18 + 2 14,000 PJ equipment trailer #9
I’d hate to put 12,500 on my 14k trailer but then again I have no need to. It should handle it without any damage. I’ve put 19,000 on my 10 ton pintle trailer but the pintle trailer is built for a beating. Most of the regular trailers aren’t. The 10 ton weighs 5500 pounds and the 14 is about 3,000 so there’s a lot more steel in the heavier trailer. IMG_8754.JPG
bdog - I have a D ring on the side rail about 9" from the corner from which I connect to now. If I can't get a D ring on the steel at the end of the trailer that might have to be my fall back position. The reason why I don't really want it there is that it would not be very far behind the attachment point on the tractor and as such would not be great at preventing the tractor from moving forward during a hard stop. I would rather have the D rings behind the tractor to better resist any forward movement.
fried1765 - The weight of the tractor with implements would not be any heavier than it is now. Often times it is about 1200 pounds lighter when I remove the forestry blade and install the finish mower. I pull the trailer with a 1 ton single cab, SRW, 4wd, diesel pickup. I have had the transmission rebuilt twice and finally now have a rock solid transmission and large cooler that seem to handle the 600 foot steep climb up to the neighborhood where I live just fine.
Thanks again for the great replies.
Blane
1987 GMC WHITE ROLL OFF (INOPERABLE) (A60736)
1987 GMC WHITE...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
500BBL WHEELED...
1997 LUFKIN 48X102 FLATBED TRAILER (A60736)
1997 LUFKIN 48X102...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
