Homemade fence unroller
/ Homemade fence unroller #21
I just use a length of 2" pipe with a "X" of scrap steel welded to the bottom that supports the roll of wire. I stick the 2" pipe through the roll then attach it with a chain swivel and suspend it from the FEL bucket. Next time I'm near it I'll take a photo and post it.
/ Homemade fence unroller #23
i onlky use mine as a transporter, unroller. believe me the ones with built in tensioner dont last. i read the reviews on them before making my own. i welded up a simple tensioner and use it with a chain on tractor bucket. fence 2.jpg fence3.jpg fence 1.jpg
/ Homemade fence unroller #24
I use a separate unroller and stretcher too. It'd be too hard to get the tractor into some of the tight corners to tension it.
I use the 48" puller that's sold by Kencove. 48" fence puller
/ Homemade fence unroller #25
Adjustable friction brake. Can unhitch and have a handle I can pull on the ground for tight spots.
That looks pretty good for barbed wire, but how will it work for 60" horse fence?
/ Homemade fence unroller #27
It will not. Have installed lots of woven wire without an unroller and thought a design for a 3pt and ssqa attachment. Have some 3” well drilling pipe with tapered threaded ends I thought would be nice for the pole thru the wire roll. Have some steel pallets with thoughts welding the pipe female socket to. Have an idea to make a combination man basket and wire fence unroller pallet. Have use for both.
/ Homemade fence unroller #28
////// HEADS UP ! \\\\\\
Didn't want to start a thread just for this but been doin some research on the DEWALT DCFS950P2 20V vs Freeman PFS9 Pneumatic 9-Gauge fence staplers . It appears depending on which product you purchase you must buy the U post nails for the Dewalt or vise versa . Even though they look simalar online or are the correct length . I came across this by reviews of people owning the Dewalt and ordering Freeman nails .....................................
Freeman PFS9 Pneumatic 9-Gauge 2" Fencing Stapler with Case - - Amazon.com
DEWALT DCFS95P2 2V MAX XR 9 GA Cordless Fencing Stapler Kit - - Amazon.com
We ended up getting the Freeman.... works great! I can't believe how powerful it is, drives 1 1/2" staples flush to the wood! Good to know that the staples aren't interchangeable. Thanks for that info!
The fence unroller also worked great, a real time and back saver! We needed to put a piece of 2" pvc pipe about 4" tall at the base of the upright post. The fence would unroll about Half way, then snag on the bolt at the bottom. The pvc stopped it from happening. The next 4 rolls unrolled perfectly.
/ Homemade fence unroller #31
Do you have a pic of the other side? B.
Scrap pile slip clutch. Thick brass washer/plate and some plate and washers cut from 1/4” UHMW sheet stock. 45# Cummins valve spring. Provides drag tension much like a fishing reel to prevent bird nesting.
/ Homemade fence unroller #33
Looks good! My dad built a similar one many years ago when we had a whitetail farm and needed to unroll 10' rolls of fencing around his 200 acres. Looks like about the only thing he did different was mount a hub and rim on the bottom so the roll of fencing would spin easier.
UNUSED IRGC40 HIGH END MINI GOLF CART (A60432)
UNUSED IRGC40 HIGH...
VOGELE VISION 5103-2 ASPHALT PAVER (A60429)
VOGELE VISION...
Gravely ZT XL-52 52in Zero Turn Commercial Mower (A59228)
Gravely ZT XL-52...
GIYI CLG72-72" HYD CURVED LOG GRABBER (A60430)
GIYI CLG72-72" HYD...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
