John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,806
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
How so? Its the original charger built into the unit that came with it new..Tell me how to change that I am all ears
I have no idea what model generator you have, or the design of the system. If I had a built in charger that that was routinely boiling the electrolyte out of the battery, I would disable it and just attach a good quality smart charger to the battery (such as one of the BatteryMinder units). NOCO makes some good units as well.
Since it's likely going to be connected all of the time and keep the battery topped off continuously, you don't need a high-amperage unit - it's not as though you are trying to recharge an accidentally discharged car battery in a short amount of time. Something like a BatteryMinder 1500 for less than $50 (or a model 1510, which is electricaly identical to the 1500) with the ring terminals, rather than the battery clips would work. (If you need something more weatherproof, get the model 1215C for about $70).
Disabling the built-in charger is more involved, but I'm sure is doable if you have a schematic.
It also may be that your charger is simply charging at too high a voltage. I'm not sure if there is an adjustment available on that, but something to look in to. Not as good a solution as connecting a smart charger, but might help.
