What else do you do with forks besides lift pallets?
/ What else do you do with forks besides lift pallets? #321
May have already posted this but I use the forks to lift the front end of my Z turn to do deck/blade maintenance.
I used to use forks to lift my lawn mowers,,
but, one year, my wife bought me a Sky Hook for my birthday,,
the Sky Hook is FAR better than forks,,,
Everything in the book, including the book! :)
Years ago when we were moving, it was hard to get all the boxes loaded into the truck because of steps and a small porch. It was a pain until we put a big pallet on a tractor with forks and slid it up near the back porch. We loaded things on it and forked over to the truck where it was easy to unload. Saved us a load of time and lots of lifting and carrying. I had forgotten all about it.
Removed a piece of heavy concrete culvert, without damaging it. Stuck the forks in the hole at the end and off the trailer came.
/ What else do you do with forks besides lift pallets? #326
Felled a decent sized fir tree and limbed it this past weekend. Started at the 'bottom' of the tree, set the forks on the ground in float position and scooped up the branches. Made quick work cleaning up the big stuff and moving it to the burn pile to burn later in the fall.
/ What else do you do with forks besides lift pallets? #327
Good stuff. Thanks for the ideas!
/ What else do you do with forks besides lift pallets? #328
Pick up a 21 bale bundle out of the truck:
Set it on the dolly in the horse barn:
/ What else do you do with forks besides lift pallets? #329
When I brush hog pasture that was logged and reclaimed bush, I run the pallet forks curled back and the frame as low as possible to the ground..
This pushes everything over in the direction I'm going and seems to help the JD 60" brush hog mulch it up better..
It also scalps ant hills for a smoother go over.. Some hills can be 4' diameter and 18" high... When you hover over them for a small bit with the mower it really messes up there day..
/ What else do you do with forks besides lift pallets? #330
/ What else do you do with forks besides lift pallets? #331
Bales are banded with steel strap, got them from a local farmer that has the machine.
The steel straps are visible here:
/ What else do you do with forks besides lift pallets? #332
Lift and transport the shop crane from the horse barn to the shop:
/ What else do you do with forks besides lift pallets? #333
/ What else do you do with forks besides lift pallets? #334
My neighbor used his forks to lift our Isuzu diesel generator and to place it on its pad.
Ralph
/ What else do you do with forks besides lift pallets? #335
I used mine to do a rear bumper repair on an old Ford Ranger I just bought (cheap).
Some photos are in wrong order. Having problems with them posting. Sorry.
/ What else do you do with forks besides lift pallets? #336
I should have bought mine years ago. I even used them to break up asphalt on a driveway. Great for picking up piles of brush.
/ What else do you do with forks besides lift pallets? #337
Emergency Wheel Bearing Replacement!
/ What else do you do with forks besides lift pallets? #338
Sometimes I wonder if Im missing out on functions by using Titan clap on forks for my bucket vs having SSQA installed and using proper forks? Im only limited to 70 pounds on the front pivot anyway.
/ What else do you do with forks besides lift pallets? #339
You absolutely are... QA bucket/fork setup is sweet. Takes me a couple minutes and I am always swapping. Of course the wrong tool is on front more than half the time. :confused3: :smiley_aafz:
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Freighliner Tender Truck (A61306)
Freighliner Tender...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
