What else do you do with forks besides lift pallets?
/ What else do you do with forks besides lift pallets? #311
Sanding and painting the bottom of my utility trailer. Flipped it up and held it in place. (I had removed the plywood deck.) IMG_20200430_150527.jpg
I also snapped off high dead branches off some cedar trees that I wanted to drive under. Faster than a ladder and hand saw!
/ What else do you do with forks besides lift pallets? #312
Move round bales:
/ What else do you do with forks besides lift pallets? #313
With the extended forks, lifting a pickup bed trailer high enough to work on the lights comfortably. Not shown was the lengths of 1.625" struc tubing that the fork tips rested on for safely working underneath.
/ What else do you do with forks besides lift pallets? #314
Forks are great for loading/unloading the half barrels of rocks that were loaded by hand. Only have to handle the rocks by hand once.
/ What else do you do with forks besides lift pallets? #315
This didn't work, but I think is a cool "Double Forking Action" shot.
I was trying to get air back in my tires after I made the mistake of deflating them so they would fit in my trailer.
/ What else do you do with forks besides lift pallets? #316
Temporary construction bridge (Big enough for two way traffic).
Looks shorter than it is. Used a home made extension a friend gave me.
/ What else do you do with forks besides lift pallets? #317
I use mine to move all kinds of stuff. Sometimes even moving the log splitter the lazy way.
IMG_20191223_115607.jpgIMG_20191223_122247.jpgIMG_20191231_144206.jpgIMG_20191231_145158.jpg
/ What else do you do with forks besides lift pallets? #318
More X-Rated forking action!
Always good for a portable workbench.
Really handy for messing about with fuel.
I have all kinds of buckets, but really they hardly get used, by comparison.
/ What else do you do with forks besides lift pallets? #319
Unloaded 240 soaking wet pressure treated 6x6's today (8ft, 10ft, 12ft) for a little retaining wall project in the coming months.
/ What else do you do with forks besides lift pallets? #320
May have already posted this but I use the forks to lift the front end of my Z turn to do deck/blade maintenance.
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
Kubota LX2620 (A60462)
2022 CAN-AM BOMBARDIER LIMITED RTV (A59823)
2022 CAN-AM...
2019 DODGE CHARGER (A59823)
2019 DODGE CHARGER...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A60352)
2023 HarbinGer V3...
