What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #311
Sanding and painting the bottom of my utility trailer. Flipped it up and held it in place. (I had removed the plywood deck.) IMG_20200430_150527.jpg
I also snapped off high dead branches off some cedar trees that I wanted to drive under. Faster than a ladder and hand saw!
   / What else do you do with forks besides lift pallets? #312
Move round bales:
   / What else do you do with forks besides lift pallets? #313
With the extended forks, lifting a pickup bed trailer high enough to work on the lights comfortably. Not shown was the lengths of 1.625" struc tubing that the fork tips rested on for safely working underneath.
   / What else do you do with forks besides lift pallets? #314
Forks are great for loading/unloading the half barrels of rocks that were loaded by hand. Only have to handle the rocks by hand once.
   / What else do you do with forks besides lift pallets? #315
This didn't work, but I think is a cool "Double Forking Action" shot.
I was trying to get air back in my tires after I made the mistake of deflating them so they would fit in my trailer.
   / What else do you do with forks besides lift pallets? #316
Temporary construction bridge (Big enough for two way traffic).
Looks shorter than it is. Used a home made extension a friend gave me.
   / What else do you do with forks besides lift pallets? #317
I use mine to move all kinds of stuff. Sometimes even moving the log splitter the lazy way.
IMG_20191223_115607.jpgIMG_20191223_122247.jpgIMG_20191231_144206.jpgIMG_20191231_145158.jpg
   / What else do you do with forks besides lift pallets? #318
More X-Rated forking action!
Always good for a portable workbench.
Really handy for messing about with fuel.
I have all kinds of buckets, but really they hardly get used, by comparison.
   / What else do you do with forks besides lift pallets? #319
Unloaded 240 soaking wet pressure treated 6x6's today (8ft, 10ft, 12ft) for a little retaining wall project in the coming months.
   / What else do you do with forks besides lift pallets? #320
May have already posted this but I use the forks to lift the front end of my Z turn to do deck/blade maintenance.
2022 Kubota Z422-54 Zero Turn Mower (A55315)
2022 Kubota...
2010 FORD F-150 (A58214)
2010 FORD F-150...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
2023 RTVXG-850 SideKick (A56435)
2023 RTVXG-850...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
