What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #321
May have already posted this but I use the forks to lift the front end of my Z turn to do deck/blade maintenance.
I used to use forks to lift my lawn mowers,,
but, one year, my wife bought me a Sky Hook for my birthday,,
the Sky Hook is FAR better than forks,,,
   / What else do you do with forks besides lift pallets? #322
Everything in the book, including the book! :)
Years ago when we were moving, it was hard to get all the boxes loaded into the truck because of steps and a small porch. It was a pain until we put a big pallet on a tractor with forks and slid it up near the back porch. We loaded things on it and forked over to the truck where it was easy to unload. Saved us a load of time and lots of lifting and carrying. I had forgotten all about it.
Removed a piece of heavy concrete culvert, without damaging it. Stuck the forks in the hole at the end and off the trailer came.
   / What else do you do with forks besides lift pallets? #326
Felled a decent sized fir tree and limbed it this past weekend. Started at the 'bottom' of the tree, set the forks on the ground in float position and scooped up the branches. Made quick work cleaning up the big stuff and moving it to the burn pile to burn later in the fall.
   / What else do you do with forks besides lift pallets? #327
Good stuff. Thanks for the ideas!
   / What else do you do with forks besides lift pallets? #328
Pick up a 21 bale bundle out of the truck:
Set it on the dolly in the horse barn:
   / What else do you do with forks besides lift pallets? #329
When I brush hog pasture that was logged and reclaimed bush, I run the pallet forks curled back and the frame as low as possible to the ground..
This pushes everything over in the direction I'm going and seems to help the JD 60" brush hog mulch it up better..
It also scalps ant hills for a smoother go over.. Some hills can be 4' diameter and 18" high... When you hover over them for a small bit with the mower it really messes up there day..
   / What else do you do with forks besides lift pallets? #330
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2002 International 9200i Truck (A55315)
2002 International...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
