Front snowplow vs rear blade for driveway snow cleanup?
   / Front snowplow vs rear blade for driveway snow cleanup? #11
I have and use both;a 8' converted truck plow on the FEL and a heavy 7' rear blade.They both have their uses.
   / Front snowplow vs rear blade for driveway snow cleanup? #12
I have both. I used the rear mount blade clearing neighbors’ driveways for cash when I was 16 back in 1967. Ford 3000/ non cab tractor with ballasted tires.
Hydraulic angle front mount would be my first choice all day long.
   / Front snowplow vs rear blade for driveway snow cleanup? #13
They all work in the right conditions.
The all are not so great in the wrong conditions.
I use a rear blade mounted on a SSQA adapter on the FEL and a pull blower on the 3ph. I get 120-140" a year...flat driveway...80'x80" area to clear between drive and pole barn...loaded turfs. Last year was first year. Never had more than 10-12" to deal with. Worked very well.
   / Front snowplow vs rear blade for driveway snow cleanup? #14
My “plan” is to use a pusher and back blade although admittedly I won’t be plowing gravel drives. Back up to OH doors, drop back blade and pull snow out far enough to use pusher. I won’t have to change directions which will save a ton of time. I live in Lake Michigan snow belt so I have to be ready for anything. If really deep I’ll head out with bucket. Wind is crazy here. Last year was a bust but this is a pic from 2019.
I PM’d someone on this site that uses a pusher on gravel I think and he liked it.
   / Front snowplow vs rear blade for driveway snow cleanup? #15
Unless your in Canada or have lake effect snow, you will be OK with forward plowing. Yes, plowing in reverse moves more snow. I do this to open up space for the next round of snow or to push it over a ravine. Chains, you may need wheel spacers.
Funny thing with FEL plow when you angle the blade it also tilts. You have to adjust curl cylinders to make blade level again. The skid shoes on the plow keep digging into my gravel, think it needs wheels like a state truck has. It maybe years of only having a rear blade but I just use rear blade now, less hassle.
If you set the plow frame parallel to the road the blade will stay level at any angle.
gg
   / Front snowplow vs rear blade for driveway snow cleanup? #16
I use the 6' back blade and the FEL - for heavy storms over 12" I run the 28" SB up/down the 250' drive, once and the walkways then clean up the remainder with the tractor. We get anywhere from 30-40" in a very light year, but average 90-120" in a typical season.
If you have the 2501 with a QA attach bucket, I'd get a manual (or electric angle) adjust on a QA front plow and then a rear blade for weight and additional cleanup. This would be your most cost effective setup as you can find used rear blades 6' and if you wanted to save more. get an older truck plow and adapt it to the QA frame.
   / Front snowplow vs rear blade for driveway snow cleanup? #17
Thats pretty ingenious setup you've got for the front - and you can use it in all seasons too! Front or back.
   / Front snowplow vs rear blade for driveway snow cleanup? #19
Not certain if this link is viewable or not but may be of interest to any members in BC.
Document Summary
   / Front snowplow vs rear blade for driveway snow cleanup? #20
I've got a 3 point blower on the back, and a plow on the front of my little Bolens/Iseki. The plow works well if the ground is frozen for snow under 8-10 inches and for any little cleaning up. More than that or if the ground is spongy and I use the blower.
It makes the tractor fairly long to have both on at once, so I have to keep that in mind in a couple tight spots. It is nice to have the weight of the blower on when plowing wet snow.
Hydraulic rail grinder (A56436)
Hydraulic rail...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
