Snow chains for plowing with a rear blade
   / Snow chains for plowing with a rear blade #61
My first snows are usually before the driveway is rock hard. Just like jyoutz - turn the rear blade 180 degrees and let the weight of the blade handle the snow. This way - the gravel on the surface stays put.
It may leave an inch or so of snow. But - I have no problems getting thru that.
   / Snow chains for plowing with a rear blade #62
I would like to try this, but my goofy Frontier blade has less adjustment holes on the back side than on the front. So I can't get enough angle to push snow off effectively with it facing backwards.
I could drill a couple more holes, but it's a 1/2" plate and I just don't want it bad enough to go to the trouble. I have no idea why they built it that way. I've never seen a rear blade with less adjusting holes when facing forward than backwards.
Interesting. Usually they have the same adjustment capability however the blade is turned.
   / Snow chains for plowing with a rear blade #63
pickup tire chains are a lot less that chains for a tractor
so why not get two sets of truck tire chains and put them
to gether on a tractor tire??? Guys would purchase a 3/4
ton pickup and they had a 1/2 ton they traded with 15 inch
tires and the 3/4 had 16 inch they would just add some more
chain to fit. I have a set of chains that fit a 975x16.5 tire haven't tried to see if they will fit out tractor and a set of VW
chains I'll just add more chain to fit. If I remember correctly
the Fleet Farm stores in Fond du Lac WI sold the chain so you
could add chain and they carried the links to hook them to
gether
willy
I would not go back to ladder type tire chains on any vehicle unless I absolutely had too. Rough bouncy ride better traction but a long way from the best and a slip grip continual motion. Many years ago I had 4 link spaced V-bar reinforced chains on my Oliver, they worked but that was all, had to have some tire speed to just make it up my driveway with the blade up. Added a set set to them to make it a set of 2 link spaced ladder chains they worked much better. Then I bought my first set of the studded Aquiline Talons, that was the ticket several multitudes more traction both going and brakeing, the ride improvement was tremendous. You could actually road travel at 15+ mph compared to 10-12. No vibration, no issues.
   / Snow chains for plowing with a rear blade #64
AGREE!
I started with 4-link v-bar ladder style chains on the rear R4 tires of my tractor. Most of the time they got me up the icy steep section of my driveway. They did not have very good lateral traction, so I'd often find myself sliding sideways when operating on side hills.
I switched to V-bar Duo-Grip chains. the design helped keep more of the chain from falling in to the treads of the tire. They gave a bit better traction coming up the icy hill, and significantly better lateral traction. I did have a bit of the grab-slip action at times as the tire rolled on and off the chain (there are some good-sized gaps in the duo-grip tread pattern). The biggest issue was the ride was so bad that on hard ground I could not go much above a fast walk without feeling as though I was going to shake the tractor apart and shake the fillings out of my teeth. They were fine when I was working in the woods, which is typically lower speed and softer ground, but they were just not practical for operating this tractor as any decent speed on hard ground.
I switched to the "Euro-style" chains (in my case, OFA EKO chains - very similar to Aqualine Talons Lou mentioned). Great forward traction, great lateral traction, no "grab-slip", and a smooth ride at higher speeds. Since these are aggressive chains, I was a bit concerned about what they would do to the pavement when we had the loop of our driveway up near the house paved. They actually are easier on the driveway than the other two styles I tried - probably because the grip is more continuous, so I'm less likely to spin the tires.
   / Snow chains for plowing with a rear blade #65
Our daytime high temps average above freezing and we also get a lot of sun. So the snow never really gets a chance to form a base over the duration of winter. Instead we get a cold spell where it snows and then it slowly melts over the next 3-4 weeks.
Sounds just like my environment. I dont even use my rear blade for snow. Mostly just use my bucket and keep pushing even if full. Gives me a 6' wide path to widen a bit. In the last 5yrs I prob had one year that the snow actually stuck around. When my base starts to melt I just put the landscape rake on to roughen the base up and a sunny day takes care of the rest.
7Yrs I havent had to move gravel out of my lawn. 700' driveway of item4.
   / Snow chains for plowing with a rear blade #66
I see someone added that the tire chains were $1200 but
this company has chains forr tractors but a lot less that the
$1200 anyone looking for chains should check out this co
willy
   / Snow chains for plowing with a rear blade #67
willy
really depends on the size and the style of chain. The diamond pattern "Euro-style" chains tend to be a lot more expensive than other styles. I bought my Ladder style and my Duo-grip style from Tirechain.com. They seemed like a decent company to deal with, though not always responsive to questions.
The OFA Eko chains I bought from a Vermont-based distributor.
   / Snow chains for plowing with a rear blade #68
At the present time I have Aquiline Talons (rear for the Branson8050) TRYGG SMT's (front of the Branson) and then three sets of the OFA' Eko's a set of 8mm (rear of the Kioti CK2620) and front and rear Eko 9mm for the NH 8160.
So far the most used ones are the Talons on the Branson, then the TRYGG's then the OFA's. I've gone with the OFA's for the slightly better price and what seems to be equal quality chains and easy availability. A few hour drive to New Hampshire and I have my chains.
   / Snow chains for plowing with a rear blade #69
Mr. Lou, think these guys may be close to you, should you have chain related needs, like repair links, etc.
They're an old style supplier with a converted mill filled with logging supplies...including lots of chains, cables and ropes. Interesting place to just walk through.
Austin Farm Enterprises, 161 Jennison Ln, Bainbridge, NY 13733.
I got my OFAs from them and can't drive by without stopping in just to look.
   / Snow chains for plowing with a rear blade #70
I've talked to them a couple of times, they are about 2 1/2 hours from me.
   / Snow chains for plowing with a rear blade #71
The prices that they listed and the many different kinds of
chains in MHO you could save a bundle but I guess not
willy
   / Snow chains for plowing with a rear blade #72
Snow clearing with a rear blade is a fantastic time to let the wife know you actually NEED that hydraulic top link you've been eyeing...the angle of the dangle is just as important as shoes and gage wheels. Since adding mine, I've been able to skip the shoes and I'm moving very little rock.
   / Snow chains for plowing with a rear blade #73
Hydraulic top link is like a good set of tractor chains. You will never know what you are missing until you have one or the other or both.
I've changed my mind somewhat. Think I will be getting chains on all four for the M6040. Get them on - get them properly adjusted - just leave them on - year round. There is nothing on my 80 acres or mile long gravel driveway that would be damaged by chains on my tractor.
I've had plenty of experience with ladder chains. Great traction - ride like a COB. I think it will be Trygg chains. I'm going to have to see it there is a local dealer handling this brand.
   / Snow chains for plowing with a rear blade #74
The 3 brands I am aware of are the TRYGG, OFA, and Aquiline Talons. My last sets have been OFA's as the pricing was a bit better, still high but better.
   / Snow chains for plowing with a rear blade #75
Oosik,
There's white mountain chain in Bonners
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
Butler MFG Water Tanker (A56438)
Butler MFG Water...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
