New trailer, farm and on-road use
/ New trailer, farm and on-road use
Alright, well I'm starting to feel a little more confident that the 3500# axle on a stock trailer might be fine for what I have in mind then.
/ New trailer, farm and on-road use #22
awesome, take some photos and let us know how it worked out.
/ New trailer, farm and on-road use #23
/ New trailer, farm and on-road use #25
If you can, find one where the tailgate will flip forward and lay flat on the bed, that will greatly improve your mileage when towing it unloaded.
Aaron Z
Waited too long. Called them today, wanted to take a trip down. Apparently it sold Saturday.
Trailers are in short supply right now in the lockdown age.
Pretty well zero'ed in on going with PJ again for this single axle. Having trouble finding one within a few hours.
Trying to decide between a regular open rail as you'd traditionally see on a landscape utility trailer, or the same but with the ATV ramps forming the rail up front. It's very unlikely that I would use the ramps to load an ATV on the front. If I did need to haul two ATVs I'm more likely to just use my bigger trailer. But, I do like the idea that I could quickly remove a ramp on either side to be able to set something on the trailer with forks. Not sure how often that would come in handy. The only problem with the version that has ATV ramps up front (other than being a little more expensive), is they then don't put stake pockets on the front half of the trailer which I would typically use for removal walls for firewood and such.
/ New trailer, farm and on-road use #28
You might want to look at Karavan trailers, currently being sold at Sam's Club as well as other places. Inexpensive but seems to fit your requirements. All sides fold down if desired, and are removable, including ramp tailgate. Only two things I added was to change out the fixed leg jack stand for a flip up, and add 6 tie-down I-bolts.
I bought their smaller one, 12' to haul my mower and/or SxS. It's also used for numerous other chores like hauling logs and brush as needed. I think I paid a little over $1K for the 6'x12' size.
Now - its not a Kaufman or PJ for sure. But then, I already have a 20' PJ for heavy duty tractor hauling, etc.. Don't need two Cadillac trailers...
/ New trailer, farm and on-road use #29
Aaron Z
Also I'd make sure that it was easy to remove that rear ramp.
If someone is loading something with a fork lift from the rear they would crush that ramp and the load will still be to far to the rear.
I modified mine to be easily removed and a fork lift can set a pallet on the trailer then back up and push the pallet further on to balance the load.
/ New trailer, farm and on-road use #30
2900 lbs may be accurate for a cord of dry softwood, but if you haul green hardwood expect a cord to weigh closer to 5000.
Exactly what I was thinking when reading some of the earlier estimates. Even a cord of White Pine weighs 3200# when green. Hard (Sugar) Maple, White Oak Red Oak, Black Locust, Hickory, American Beech all generally weigh over 5000# when green, some of those species can push close to 6000#. Even when dried down to below 20% moisture content (recommended for burning firewood), they still range from 3500# to over 4000# per cord.
If you want to haul a cord of firewood, go with the heavier axle.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
CFG Industry ECAG QA Auger w/ Bits (A60463)
CFG Industry ECAG...
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
2020 Bobcat T76 R Series (A60462)
2020 Bobcat T76 R...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
