Yet another trailer decking question...
/ Yet another trailer decking question... #21
The metal on your trailer looks in amazingly good condition. White oak will be awesome.
Thanks. It's starting to rust and bubble in a few spots, and I'm debating on how to deal with that. Any place I have ever repaired via rattle can seems to not hold up, but I really hate breaking out the HVLP gear for spot repairs. Maybe I just need to do more and thicker coats when I rattle can it.
I'm honestly debating between doing a bunch of spot repairs with the needle scaler, versus just hauling the entire trailer to our local sandblast/repaint place. My primary apprehension, other than sinking more money into a trailer than it's worth, is that I've heard the blasting sand can get into and ruin the running gear. I really don't feel like pulling hubs to clean out and re-pack bearings, or dropping springs to clean the shackle bolts and bushings.
Oh, and confirmed when scheduling inspection this morning, this trailer is a 2016 model. Deck has been failing for more than a year, so it really only lasted 8 years. Thats pretty bad for pressure treated, obviously the older CCA stuff was better (and less corrosive) than this ACQ crap we have been forced to buy the last 20 years.
I already decided that the new white oak will get hosed down liberally with Bora Care as I stack it with stickers to dry. Unfortunately, I seem to have tossed my bin full of hundreds (thousands?) of wood stickers, so I'll be spending some time today making new ones.
(...and before anyone asks: wood "stickers" are small sticks that go between planks when drying, not adhesive labels.)
/ Yet another trailer decking question... #23
I used a needle scaler on mine earlier this year. Some rattle can paint is touted as one coat coverage. Why not if it only needs touching up in a few spots?
Boards are home, treated, stickered, and in the “kiln”!
I’ll have to lift the plastic at the ends after the next rain passes, to seal the board ends with paint or wax. Today was all a rush to get them treated and covered before tonight’s rain.
There’s some real nice figuring on some of the boards, as quarter-sawn oak tends to have, nice striping and ray flakes. Almost a shame it’s a trailer floor. 😀
/ Yet another trailer decking question... #25
Just asking...
Is there any airflow in and out of the "kiln".
Just asking...
Yes, there's a gap down each long side, but I'm not convinced that's enough. I plan to add some stringers to the long top corners, attaching them to each end of the cross members supporting the pipe, just to gap the plastic off the oak a bit better. But if you have any advice on how to optimize ventillation, I'm all ears!
I know there's a sweet spot, adding enough ventillation to let trapped moisture out, without allowing much heat to escape. As it is now, it's vented from below, and any evaporating moisture should condense on the plastic and drain down to the edges at night. But I have no real experience with this, I'm just copying what I've seen others do.
/ Yet another trailer decking question... #27
There's no need to kiln dry oak for a trailer deck. I'd let it air dry for a week or two and then bolt it down. If you were making furniture, sure go the kiln dry route.
I move about 60,000 pounds of oak per year, I know the wood better than most. White oak in particular takes about 3 years just to reach 18% moisture content, and our equillibrium moisture content (EMC) for white oak in this climate is around 15%. Did I mention I use a lot of white oak? :ROFLMAO:
Fresh cut white oak has very high moisture (45% to 200%), and my goal is to knock it down at least a little closer to the 15% EMC for our area before installing, to avoid having it just tear the deck fasteners out as it dries from this fresh-cut state. The only way to do that in a matter of weeks, rather than a matter of years, is to kiln it.
/ Yet another trailer decking question... #29
I don't know if it would make a difference, but you could remove the old trailer deck and use the trailer frame as a drying rack to get the oak further off the ground and away from ground moisture.
My experience with sawmill red oak used as siding is the width shrinks a surprising amount after it dries out. I haven't worked with white oak, but if white oak shrinks like that, I'd want it as dry as I could get it.
Flat sawn white oak 8" planks will usually shrink about 1/2" across their width between milling and EMC, depending on initial moisture, exact sawing orientation, etc.
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
2024 Linx EQ07018RS (A60463)
2024 Linx...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
(10) Mini Ex Bushings (A60463)
(10) Mini Ex...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A61165)
2014 Chevrolet...
