First Time Tractor Owner
/ First Time Tractor Owner #1
reylas
Husquvarna
I am taking delivery of an LS MT125 TLB this weekend and I have a general question. I am buying because I have always wanted one since a little boy and intend to do light landscaping, ditch cleaning and dirt moving. Having said that, I have never owned a tractor before. At this point, I own a 5 gal diesel can. What would you recommend a tractor owner have on hand? Any tips on a grease gun? What else does a Sub-compact tractor owner need to keep on hand?
I know that I am a little inexperienced with tractors, but you have to start somewhere right? I routinely break down my riding lawnmowers and replace parts so I am decently handy with tools.
Any advice for a first time tractor owner? What do I need to keep in stock?
Thanks,
Mark S
/ First Time Tractor Owner #2
You should have your dealer go over the tractor with you, thoroughly! He’s bound to have been around tractors a lot. You can also go on YouTube and check out Menard’s tractors. The guy has many short informative videos on tips & tricks for many things.
Congratulations on your purchase!
/ First Time Tractor Owner #4
Thanks,
Mark S
You should always have a tip on a grease gun, Lock-n-Lube or similar is highly recommended.
/ First Time Tractor Owner #5
Personally I like the battery powered grease guns. They are a bit pricy. Hand powered ones seem pretty much the same if they are in similar price range. Some people like the lock and lube on tips that can be installed after purchase.
Fuel might need additive to prevent Algae growth if you are not using a can up every couple months at most. If your in a cold climate and have filled your can up in warm weather you might need winter fuel additive if it’s put in the tractor during winter.
Tire air gauge
Some day when it’s time for filter changes be sure you have them already. Not unusual to have to order them and with this COVID stuff some Filters might have limited availability for some time into the feature.
Spare oil and hydraulic fluid for keeping it topped off as and if needed.
Spare fuses
Kind of off subject but keep in mind. Do not travel with the front bucket up any higher than absolutely needed.
Wear the seatbelt. Stuff happens that are to numerous to list. Especially if using the front loader.
Does your roll over protection and backhoe clear the top of barn door frame, shed roof etc. It’s REALLY common for people to forget and hit things.
/ First Time Tractor Owner #6
:welcome: to TBN and congrats on your new investment. :thumbsup:
Have chat with service tech,do TBN SEARCH for there been many threads on this topic.
Again congrats and we all like pics. :)
/ First Time Tractor Owner #7
Congratulations, your going to love everything you can do with your tractor.
You might consider some chains because you will want to pull or lift things. Extra lynch pins because they have a way of disappearing.
/ First Time Tractor Owner #8
G'day Mate and welcome to TBN from Downunder.
By all means, go over the thread recommended by mred2. Read your Owner Manual (twice!) and go 'low and slow' with your tractor/Front End Loader (FEL)/implements. Grease everything and if it moves, but can't be greased, spray-lube it. Tighten/snug every bolt/nut you can find & ensure the wheel lugs are torqued.
Enjoy the site.
/ First Time Tractor Owner #9
Congratulations on your first tractor! You will love the mt125! When I had mine, it did everything I needed it to do!
Like everyone else has said.... GO SLOW! Learn the machine. It is not a toy and can be very dangerous, especially with a full bucket. Use common sense, it will be your best indicator.... if you question yourself if you should do something, odds are you shouldn't!
For a grease gun (you definitely need one) a good quality air driven one would be affordable. They can be had for around $30-50. I got one from O'reilly's auto parts for $30. Its a few years old already and at least 2 cases of grease through it... no problems. You would just need to have a compressor. Make sure you grease all the fittings about every 10 hours... sooner if you hear any squeaking.
If you put a general location in your profile, it might help for more specific questions you have about operating the tractor. Your dirt might be a lot different than mine.. or the next guy...
Again, get familiar with the tractor, and HAVE FUN WITH IT!
/ First Time Tractor Owner #10
Oh, check out the LS tractor thread further down in the forums. There are a bunch of MT125 owners there and a lot of great threads on the tractor.
/ First Time Tractor Owner #11
https://tym-tractors.com/wp-content/uploads/2015/05/TX5000_Opration-Manual_110117.pdf
this is just to give you some reading material about your front end loader starting at about page 9
it has decent in illustration's , just basics of operating a bucket and such.
just trying to help
hope you enjoy your new tractor
ps pictures help me understand basics of stuff
ps #2 I know it a different make of tractor but liked the illustration's
/ First Time Tractor Owner #12
I have Massey Ferguson GC 1715, and so far I get by (for 2 years now) with a 5 gallon diesel fuel can (the small engine just sips fuel), an $25-$30 manual grease gun (that takes tubes of grease) and some basic hand tools........Biggest time consumer is checking coolant and engine oil and sight glass for HST fluid ..... Real problem are lynch pins and "R" pins that go missing and small hardware like clevis's and rings to attach chains and ropes for dragging stuff and getting implements matched up to quick hitch... Oh yeah, a quick hitch...
Do not go out and buy a bunch of stuff because you "think" you might need it, buy what you need when you discover you need it, and for some items a spare...
One thing I highly recommend if you are going to do heavy lifting with front end loader is a rear ballast weigh on three point hitch....
And maybe some bucket hooks on bucket IF you are going to strap things in to bucket to keep from spilling them out of bucket... Good for lifting things too...
There will be other things as you go along, just get then as you need them....
Dale
2016 FORD F650 ROLLBACK (A59909)
2016 FORD F650...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
207269 (A52708)
207269 (A52708)
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A61568)
2015 Hyundai...
2001 John Deere 6210 Tractor (A64047)
2001 John Deere...
New/Unused Landhonor Quick Attach Hydraulic Winch (A61166)
New/Unused...
