Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,901
I don't see how the mower can sink like you mention as it is all the way down already and if the front is tilted up via the top link there should be no scalping because of that. Your top link looks to be a manual, not the cylinder type like I have so how can the mower sink down?
My 3 point lift arms are not 'bottomed out' when my mower is mounted on flat ground. So if you imagine the tractor backed up to the edge of a cliff, the mower would drop maybe a foot before 'bottoming out' the lift arms and hanging in mid air.
So I'm thinking if I set my lift arms up so that this settling didn't occur, it might help with the scalping.
This mower has been a real PITA. It cuts nice but I'm kinda wishing I just bought a nice brush hog.
/ Let's talk flail mowers #6,902
From what it appears in your photo image the problem is that the original anti scalp skids are gone.
At some time prior to this the skids were removed or worn off.
Properly adjusted skids prevent the mower from nosediving and breaking side slicer knives and knife hangers
If you are able to loosen the clamp bolts for both the lower links go ahead and reposition the lower link arms up at least 2 teeth counter clockwise that will help a lot. if you have telescoping lower link arms on that mule unclip them and remove them before loosening the clamp bolt for both lower links so you have less weight to deal with and after you have reset their position by 2 teeth reset and pin the lower links with the arms fully extended.
Use a fine tip sharpie to locate the gear tooth at 12:00 before you remove the lower links as it will be easier to manage and not cause the lower links to be off a degree or 2 as remounting the mower or other implement will become a real PIA.
Use the sharpie to mark the inside position of the two teeth to the left of the 12:00 position ON THE STUB SHAFT and you will not lose track of the point where you must set the lower link arm. Please be careful when removing it as it is going to be very heavy.
Perhaps if you have a sheave pulley you can hang it over 2 or three rafters with a piece of rope prior to removing the lower link lift arms as it will prevent any surprises like losing your grip on the lower link arm-been there done that NOT PRETTY even the small ones hurt.
If you have telescoping lower links on this mule they should be pulled out all the way and then pinned back into place.
Flail mowers with wheel sets mounted in front prevent scalping more effectively and keep the mower from dropping and breaking knives and knife hangers.
Happy mowing Thoner7
/ Let's talk flail mowers #6,903
I can assure you the mower has all the pieces there. I have the manual which shows the mower as it is, plus pictures of other units online look the same.
So unfortunately my problem is more than just missing skids. Maybe it was an older, bad design.
Looking at it now compared to other brands, it's much shorter than other makes. The other, deeper ones Naturally have more protection via the skids. I trip to the welder may be in order......
/ Let's talk flail mowers #6,904
You can try some "check chains" to keep the lift arms from going lower:
/ Let's talk flail mowers #6,905
Anyone recognize this flail, who the manufacturer might be?
/ Let's talk flail mowers #6,906
I think I figured it out. Looks like it's a Mathews Company product. Not sure the vintage. Here's a comparable, model stated as 7HDCL:
MATHEWS COMPANY 7HDCL For Sale - YouTube
Stalk chopper. Paddle type flails which aren't likely available and which won't serve the purpose I need: I need to cut grass and tree debris.
/ Let's talk flail mowers #6,907
Hello DieselBound,
The paddle knives should still be available from Clean Cutter or Mathews. They will cut grass for you but they will not recut the grass unless its brittle.
If you need to break up pruning debris you will need a flail mower with heat treated/hardened side slicer knives or make two or three passes over the
tree debris to break it up with the paddle flail shredder..
/ Let's talk flail mowers #6,908
Has anyone installed standard grass knives on the Chicomm flail from Titan/Palletforks in place of the standard hammer flails? If so, where do you order them? While the hammers are fine at destroying Buick hubcaps and other debris, I would like a more finished cut at some point once I have the field in Bermuda. Thanks.
/ Let's talk flail mowers #6,909
Called Woodmaxx they could not figure anything for sure but because it is less than a year old they are sending me a new hydraulic cylinder.
Well I put on the new hydraulic cylinder and it took care of it. It now slide just like new. Thanks for all the advice
/ Let's talk flail mowers #6,910
Sorry no chicomm flail mower experience, but I put these from Flailmaster on my Ford 917L just recently.
They cut my field pretty nice and can handle small sticks & branches fine, but I am trying to avoid bigger pieces of wood - work so well that I just bought a second set for future spares.
They were close to dollar apiece including shipping cost.
Here is OEM vs. Mott's MH386
I had to drill the holes from 7/16 to 3/8"
/ Let's talk flail mowers #6,911
YES, ME. My 2501 pulls the woodmaxx 60 inch just fine cutting very tall reed canary grass. This setup is much more than I thought it would be, very happy.
Ricn
/ Let's talk flail mowers #6,912
Another question..... How often do you guys need to replace blades or hangers on your flails? Not because they are full, but because they've broken off and are missing????
For example, I have 7 missing from mowing maybe 4 acres yesterday. This to me seems like an incredibly high number to lose.
Look where your top link is mounted to the tractor. Are there holes that you can lower the top link position? I did this and it dramatically reduced my scalping. The mower now tips as it goes up and down over hills due to the altered geometry of the top link.
Are you tearing out the hole in the mounting flange on the rotor or just losing your cutter and link? Or are your nuts loosening on the hanger (the part that bolts to the rotor flange)? What did you lose and what is still there? that will give you a good indication of what is going on. If you tear out your mounting hole in the flange either the flange is weak or you're doing some serious damage when you mow. If you're losing the whole assembly then likely your nuts are coming loose. If you lose just the knife you are probably hitting stuff. If you lose the link as well then I have no idea what went wrong there.
I lost a few knives when I sucked up a hidden 4" tree branch. Otherwise I don't lose knives. On my old 917 I saw a few of the holes in rotor flange were torn out before I got it. Check if this is happening.
/ Let's talk flail mowers #6,913
A bush hog is simply far more durable and less "high maintenance" than a flail. I like the flail, feel I can mow a smoother consistent mulched looking path left behind it, and seems faster (7.5 ft flail) than my 7 ft hog more so than the 6" difference. That's great in grassy places where there is little heavy debris. In a pasture field with rocks here and there, fence post sized limbs and debris in 20 places per acre, etc. the bush hog keeps right on going and the flail makes me stop and replace knives and hanger clevises a couple of times per day of mowing -- and that's when I am super careful to lift the flail over any visible limbs that are too large. I'm getting ready to put my nice hefty trouble free hog back on next trip to the farm.
Now about all these scalping reports -- one guy saying he was missing 7 knives !!?? ****, ONE knife pair missing on my age old Alamo SD88 makes the vibration so bad I know darn well I have to stop and fix it. Seven is a severe exaggeration or just crazy. I am pretty sure that most if not all flail mowers we speak of here have a common design feature -- namely a trailing roller in back with a rotor carrying knives that "hits the grass first." That design inherently means that your TOP LINK is what sets the mowing height (given that you have the roller bolted in at some workable height and are not screwing with it often.) So those with "scalping" concerns need to run their top links back/longer which raises the flails higher off the ground. I love my hydraulic top link for many reasons and that is one more -- allows me to adjust cutting height from the driver's seat.
Other discussion about lower lift arm adjustments, limiting their travel, etc. to me are irrelevant and have little or no relationship to scalping issues. Also the discussion about skids seems off the mark to me too since my skids rarely touch the ground and normally ride around 2-3 inches above the soil. My opinions of course...
Bouncing around here a bit -- this thread is more like a 12 guage with bird shot than it is like my 243, shots going everywhere -- friend FarmerInAdell says "If you lose just the knife you are probably hitting stuff." and I agree 100%. That's exactly what happens to me. But FarmerInAdell also says he lowered the top link position in the multi-hole "beam" that anchors the top link and found dramatically reduced scalping (??) That should not make any difference. In his experience apparently it did make a big difference, but I can't understand how it makes any difference in geometry that logically affects scalping. Maybe he or others on here can explain that one ?
/ Let's talk flail mowers #6,914
When going over my ditches and hills the mower tilts as the 3 point arms go up and down. So when the tractor is on the level but the mower is still on it's way out of the ditch the mower is tilted to the angle of the ditch instead of being level with the tractor. And when I'm going down a hill and the tractor makes it to level the mower is still on the hill, it tilts to the angle of the hill. Lowering the top link at the tractor mounting point will effect the arc of travel of the top link compared to the lower links. Instead of the mower staying parallel with the tractor it tips with the 3 point lift arms a bit. Think of a fork lift vs front end loader with the way the bucket or forks move.
/ Let's talk flail mowers #6,915
OK, I can see that. Now that I understand the change in the arc, I'm still surprised it makes that much difference in the scalping. Interesting.
/ Let's talk flail mowers #6,916
Try measuring the angle of the mower at different points as it's raised an lowered by the 3pt. When you get to where the top link is level, it will have the mower tipped back as far as it will go. When above or below that point, the top link's angle will pull the top of the mower in which will reduce cutting height. The 3pt arms' angle will have a similar effect with the bottom of the mower but less because they are longer.
/ Let's talk flail mowers #6,917
I find this discussion about scalping problems with flail mower interesting!
:confused:
I have used my 60" Ford 917L now three times for mowing our pasture and a forest. The pasture has reasonably level ground and the flail does a nice job mowing it but the forest area has several nasty uneven areas where the flail mower has worked beautifully so far and without any scalping at all. It's set to about 3.5 inch cutting height.
My 48" JD brush hog has always given some trouble with scalping in the uneven forest areas but it can handle it no problem, I just don't like the looks of it!
/ Let's talk flail mowers #6,918
The hanger on the right end is partially dislodged and needs to be secured before running again. The mounting tab on the rotor appears to be bent already. Be very careful if bending back not to crack the weld.
I prefer the flail mounting method on my JD mowers. I.E. continuous axial rib with formed flat straps that secure D-ring blade hangers. The down side is that the corners of ther blades can hit the rotor, dullling them. But no individual tab welds to break.
/ Let's talk flail mowers #6,919
This machine has identical hangers, knives, clevises and pins to my aged Alamo SHD88. Typical I hear of roadside maintenance equipment. VERY repairable and maintainable. If I were you (unless you do your own welding) I'd take it to a welding shop and have the left support heated and straightened and just put it all back together. I can't see the dislodged right side hanger but of course weld that back solid to the big rotor shaft too. Not a problem.
I'm not familiar with the JD mounting method -- got any pictures of that?
/ Let's talk flail mowers #6,920
The only scalping issues I've had is when the mower drops below the tractor while mowing my ditches perpendicularly. That's where moving the top link on the tractor side helped. The other side of that is when the mower is higher than the tractor it was leaving the grass long, again solved by the top link adjustment. I would also like to note that I use this mower for my lawn so I leave it at about 2-3". If I have time this weekend I'll try to get pictures or video to show how this works. In a perfect world I'd add wheels to the front of the mower and float the top link. I just haven't had the ambition to do that yet.
2003 McCormick XTX 185 XtraSpeed Tractor (A63118)
2003 McCormick XTX...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2011 International DuraStar 4300 Petersen TL3 Forestry Grapple Truck (A61568)
2011 International...
(4) Tex Star 205/75D/15 Tires and Rims (A64047)
(4) Tex Star...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
UNUSED ATS T460 STAND ON SKID STEER (A62130)
UNUSED ATS T460...
