The Best PTO Quick Adapter Ever!
/ The Best PTO Quick Adapter Ever! #21
If your shield is already off stick a long screwdriver through the yoke and rotate the implement shaft till the splines line up. Keep your $$$.
/ The Best PTO Quick Adapter Ever! #22
Reminds me of the 'Lock N Lube grease coupler thingy. An idea looking for a home where someone will pay for it. I'm 70 and never have any issue hooking up my pto shafts and I have a lot of driven implements.
/ The Best PTO Quick Adapter Ever! #23
Well im 83 and it was a BIG problem for me with the new type pto’s that you cant turn , i have to get my wife 82 to turn the 6 mower blades or the 5 tiller while i try to line it up.
I have also hooked up hundreds of times with the old style By myself that you could rotate the pto shaft.
Im case i love the ease of now being able to hook up by my self thanks to Tonys post.
/ The Best PTO Quick Adapter Ever! #24
So your tractor doesn't have a lever to put the PTO in Neutral? Tractors with multiple PTO speeds or with mid PTO, have a lever to switch between speeds or mid/rear PTO and will have a Neutral position too.
No it does not and turning the key on and elec pto on dont make where i can rotate it
I removed the pto shield when tractor was new
/ The Best PTO Quick Adapter Ever! #25
Many do not have a PTO neutral. I'm fortunate that I can switch to mid PTO and free the rear to turn by hand.
