New garage time!
/ New garage time! #601
Will plywood squeak on metal joists? I've never encountered metal joists before and wonder if it's even an issue.
The only thing that I can think of that would stop squeaking, if it happens, would be the tape used on metal roofs. I'm drawing a blank on what it's called.
Butyl?
/ New garage time! #602
We built around '89 and over the years the floors have developed quite a few squeaks. We used T&G plywood and it was all glued and screwed. I've read a lot about fixing the squeaks and a couple sources claimed squeaking is sometimes caused by the joints in the plywood - where they run perpendicular to the joists moving slightly. At least one said the cure is to run a saw on the joint to create clearance between the sheets.
I'm almost looking forward to replacing the floor coverings just to make it stop.
/ New garage time! #603
Can you get underneath it? Just toe screw through the joists back up into the floor ply.
/ New garage time! #604
I used a polyurethane construction adhesive in my work truck (Sprinter) to attached plywood to the sides which were metal and it has held up very well. Been at least 8 years.
/ New garage time! #605
Butyl
/ New garage time! #606
I can get under the first floor, but not the second. There's unfaced insulation between the first floor joists that I'd rather not mess with.
/ New garage time! #607
I would talk with the metal joist guys for their recommendation. Maybe there is a compressible tape that can be laid down on the top flanges?
/ New garage time! #608
You talk like squeaky floors are a bad thing. I live in an old house. I think the squeaky floors are just part of it's character. Probably because it's easier to enjoy the floors squeaking rather than fixing it.
There's probably a glue that will bond to both wood and metal.
I have a few squeaks in the hardwood floors here and there. Someday I may look into fixing them, but they are really not that bothersome. The last house I had (1949 build) had so many squeaks you could tell what room someone was in just by listening to the squeaks. Just part of life.
/ New garage time! #609
I hate squeaks... at a minimum I would put a bead of construction adhesive along all the top flanges but the issue is that metal and wood expand at different rates, thus my thought of a foam tape of some sort might be the ticket.
/ New garage time! #610
I think the roofing butyl tape would fit that.
/ New garage time! #611
I had one area maybe 3'x3' in my 1yo 3/4" hardwood floors that freaked as I walked over. Bought the special screw kit that breaks the head off and 4 screws later, all gone. Well worth the $25 kit. I HATE squeaks!
/ New garage time! #612
I absolutely agree in an old house. This is not.
/ New garage time! #613
Yes, just wondering if there is something else that is cheaper as it doesn't need to be a waterproof barrier. Butyl tape is pretty expensive.
/ New garage time! #614
Might have to be concerned with degradation over time, especially foam. Perhaps butyl caulk, but convenience of the tape may offset.
/ New garage time!
I don't know if I mentioned this before, I don't think so. I ordered 24' joists for a 24' wide building. That was a mistake. Not only did I not take into account the 12ga thickness of the rim track pieces, I also didn't take into account that the c channel isn't a hard 90 degree's, it's a bend, which means you can't get them all the way flush. The result of course being nearly 1/4" overhang on each side.
Additionally, getting them seated properly was a pain. The pre-drilled holes in the flanges for the rim track were inconsistent at best, which was tough because getting them in snug required ratcheting every one in as tight as I could get it, then wailing on it with a dead blow hammer, then screwing it in.
Also by comparrison, the first 2 days we got 2 installed working 8 hour days. After the drywall lift was discovered, the second 2 days we got 28 installed, and we were working 5 hour days.
/ New garage time! #616
We have done a few jobs where they specked out pl 2000 premium some not,. Remember they aren' t wood joist no shrinkage no nail pops screws hold alot better than nails . 40 years of commercial metal frameing never had a piece of plywood properly screwed to a metal stud come apart. If you try to glue it make shure the studs aren't hot otherwise you glue will just be a runny mess. And don't glue over morning dew. When ever we had to glue it because the print called for it it always seemed like a waste. Why is the track [box beam]sticking past top plate ? Oh yea been glueing some HD connor gaurds on rock and plwood with locktite construction adhesive in the red tube that holds like a ******* if it floats your boat.:drink:
/ New garage time! #617
Valid concern. Typically though it is UV or thermo-cycling that would accelerate the degradation of 'plastic' materials. This application doesn't have significant 'exposure'. Because this construction is relatively new in residential builds there may be materials that haven't been considered that are also effective. Excuse me while I think a bit outside the box.
Of course you can just blast a bunch of screws in the flooring and call it good. I haven't been paying close enough attention to the second floor use... we may be over thinking/engineering this.
/ New garage time! #618
Sorry must be blind or stupid forgot the part about ordering studs full 24' .:ashamed: They could have easily been trimmed down with a circular saw and a metal cutting blade. Most supply houses will not cut studs to exact length anyway. Gotta be getting sick of the peanut gallery critasizeing you after your finished , hind sight is 20-20. No harm intended just trying to help.:drink:
/ New garage time! #619
Seems many of my valuable lessons have been learned on the wrong side of the curve. Part of what makes TBN so great. 🤙
/ New garage time! #620
On the bright side, the joists are all screwed in and not nailed. So... all you have to do is remove all the screws and joists so they can be trimmed 1/2" or so and then put back together. ;)
JOHN DEERE 6420 TRACTOR (A62130)
JOHN DEERE 6420...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A62130)
2020 CHEVROLET Z71...
