a stand for a HD kingkutter cat1 /cat2 3 point trailer mover
/ a stand for a HD kingkutter cat1 /cat2 3 point trailer mover #1
sleepydeere
Woolwich, Maine
4052 R John Deere
Hi I have a HD 3 point trailer mover, and look for ideas on a stand for it ,when I'm not using it . it weighs 180 lbs my new Jd 3 point don't go to the ground like my 870 JD I have a land pride QH15 speed hitch on the new one any ideas would be great thanks Mark
/ a stand for a HD kingkutter cat1 /cat2 3 point trailer mover #2
All you need is treated 4x4's, lag bolts and a saw. Build stand under it while attached to tractor with 3pt in center position. Keep adding 4x4's in layers for desired height. Flipping unit over and adding deck boards will help keep 4x4's sinking into dirt over time. Treated 2x lumber may be cheaper than deck boards.
Not that heavy but why pick them out of ground when you want to use them.
Thanks i7WIN7 for the info and idea Mark
/ a stand for a HD kingkutter cat1 /cat2 3 point trailer mover #4
i7win7, neat and simple designs
/ a stand for a HD kingkutter cat1 /cat2 3 point trailer mover #5
Had similar issues with a 500-600 pound ballast box, just built a pallet large enough to be stable and high enough I could engauge/disengage the QH "hooks"....
Dale
/ a stand for a HD kingkutter cat1 /cat2 3 point trailer mover #8
Maybe supply issues are starting to recover, bought mine at local Menard's (east central Illinois).
thanks for all the info and great ideas Mark
/ a stand for a HD kingkutter cat1 /cat2 3 point trailer mover #10
I will have to look
Flatbed Truck (A55973)
2008 UNKONW  SPOOL TRAILER (A60736)
2008 UNKONW SPOOL...
TANK MANIFOLD (A58214)
2003 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2003 V.E...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
