Straight cuts with plasma cutter.
   / Straight cuts with plasma cutter. #11
Not cheap, but really handy -I have one of their guides for my Hypertherm. The "chariot" wheels eliminate uneven drag due to surface roughness (uneven movement due to the OPERATOR'S coordination is another thing :confused:
Hardware threading is standardized @ 1/4-20, so pretty easy to kluge together other add-ons -
Plasma Cutting Guide | Flange Wizard
Note to DragonEggs: Yeah, you DO need one :D ... Steve
   / Straight cuts with plasma cutter. #12
For small projects I have used the harbor freight magnetic tool holders since I gathered a few when they were free or cheap... just stick it to the metal, offset to where you need to be and go for it. With the steel surround around the magnets there isn't much magnetism outside of the metal, I didn't notice anything too odd and it was super easy... I don't have drag tips but used the guide thing on the cup to follow the straight edge.
   / Straight cuts with plasma cutter. #13
Check out this radial arm saw conversion by Rednic 79. I think it's a great idea and plan to make one similar.
YouTube
I saw that Youtube vid several years ago and almost did not sell my dad's old radial saw that had been collecting dust for about a decade. After several years of contemplating a poor man's CNC table, I ended up having to get rid of it to make room for new and bigger jointer. Was sad it see the 60year old Craftsman go.
Ha, ha... I started to click on the link before I read your note at the bottom! Thanks for thinking of me.
   / Straight cuts with plasma cutter. #14
People get pretty creative. I saw a guy using and old roller skate stripped down with hole in the center. That was his cutting guide. You can actually buy the circle/straight cutter kit from Tangent or Victor. Does bevels, straights, circles. I have the fancy set with magnets, wheels and a suction cup for aluminum.
   / Straight cuts with plasma cutter. #15
Yeah, I'm definitely NOT shy about inventing/"xerox engineering" stuff, but when I bought my kit I was working up to 84 hours a week and maintaining 10 acres in my "spare time" - so I just bought this one (a couple hours of OT at the time :rolleyes: )
Plasma Cutting Guides - plasma cutting guide w/1.7 bushing - Power Plasma Cutters - Amazon.com
(Mark, unless the 45xp ships with a different torch than my PM45 that is the EXACT one you need)
Then I took a piece of 1/4" cold rolled rod and threaded one end 1/4-20, cut it off to 6" to replace the 18" one that comes with the kit; when doing smaller than maybe 12" holes, that extra rod length just gets in the way.
I took another 3" piece of the 1/4" rod and pencil-pointed one end for when the "Z" shaped pivot point isn't needed - the "Z" IS DEFINITELY needed for holes smaller than about an inch IIRC - you offset the point TOWARD your hole, makes up for some of the hardware limiting you to how small you can go... Steve
   / Straight cuts with plasma cutter. #16
WOW. $105 for two cutting wheels from a pipe cutter, a couple of 1/4" bolts and a 1/2" long piece of pipe.
   / Straight cuts with plasma cutter. #17
About the same dollars I sold my old radial arm saw. :mur: :D
   / Straight cuts with plasma cutter. #18
Check this one out. Only $8 There is a picture on the Welding forum post 1205
   / Straight cuts with plasma cutter. #19
   / Straight cuts with plasma cutter. #20
Awesome. This thread will inspire those in need to make their own. Oh the beauty of it.
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
2015 Ford F550 Bucket Truck - Versalift VST47 Boom - Powerstroke Diesel - Automatic - 4X4 (A55302)
2015 Ford F550...
2014 Electric Cart (A53424)
2014 Electric Cart...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
