JD X749 Dying after 30-45 minutes
/ JD X749 Dying after 30-45 minutes #101
Air flow wouldn't make it shut off like a switch. I would think you would see lots of black smoke as the fuel mixture gets richer with diesel cough and then stall. It sounds like something is getting sucked dry and it's taking time to fill back up. The longer you wait the more it fills back up. Or something is heating up and shutting off and as it cools back down the cooler it gets (more time) the longer it takes to heat back up and shut off.
/ JD X749 Dying after 30-45 minutes #102
the fuel cutoff solenoid is the only electrical device that could stop the fuel, that was replaced, and the voltage monitored and the solenoid gets constant power, so it's not an electrical problem..
Again as usual bad advice.SIGH..
/ JD X749 Dying after 30-45 minutes #104
you really like annoying people with silly comments don't you?. what I post is sound!..
Nope just stating the facts.PTO switch RING A BELL?Sorry you are annoyed.Miss ya at the Kioti forums.Have a nice day.
/ JD X749 Dying after 30-45 minutes #105
Two year old thread on GTT discusses what appears to be the same issue, shutting down after a period of time. Mentions a temperature cutoff switch, but there is no resolution to the thread.
/ JD X749 Dying after 30-45 minutes #106
Have not read the entire 13 page thread but has the OP had the JD dealer diagnose his JD tractor?
/ JD X749 Dying after 30-45 minutes #107
Unless they changed the design of the shutoff solenoid mount in the pump you should be able to remove the shut off solenoid and run the tractor. You won’t have any safety shut off function nor will the key shut it off. To kill the engine you would have to use a small screw driver to push in the mechanical plunger inside the injection pump. (I suggest familiarizing yourself with this before starting the tractor)
That would completely rule out any electrical issue with shutdown. All safety and engine protection included. If it still shuts down it’a a mechanical problem. Problem in injection pump, or a restriction in the fuel lines. Likely not air restrictions because it would smoke profusely before it died.
The mention of keeping it from shutting down by lowering the throttle or cutting off the pto indicates a fueling issue. Doing both those reduces the engine load and fueling requirements.
You keep arguing against electronics or anything else other than fuel, but this implies differently. If that PTO switch or some other switch, safety or electrical component, wire or connector heats up with time and closes, or opens, it could cause these symptoms.
I'm also wondering about airflow that slowly gets restricted over time.
What I don't understand is how consistent the timing seems to be. Did somebody install a cutoff timer when you weren't looking forcing you to take breaks?
Actually, if you go back and read from the beginning that is exactly what I thought it would be. Per everybody here there is nothing that turns the motor off, so if you are aware of something other than the ones you mentioned I open for investigation.
Airflow is also fine.
Sorry if you answered this but I can't remember. Does it have a clear fuel filter? If so is it empty when it dies? If not installing one before the fuel pump would confirm that the pump has fuel when it dies.
The only two things that come to mind that were similar to what your experiencing were on my Case backhoe it has an in-line filter along with a canister style filter. The in-line filter is just a metal one that's spliced into the fuel line. It's two halves that has a crimp to hold them together. It's before the fuel pump. The crimp was very lightly rubbing on something and wore a very small hole in it. It was too small for diesel to leak out but it would suck air in. When running it was fine but if I shut it off it would turn over for ever. Without a diesel leak it was very hard to find.
The other issue that comes to mind is a coworker had a similar problem. He had gotten some hay in his fuel tank and it would run fine and then shut off but I thought he said it was after a random amount of time. He had to pull the tank and clean it out.
Been through that one as well... clear filter housing full to the brim every time.
Nothing found int the tank as well.
And yet he talks about the PTO switch apparently having some effect.
No effect other than me trying to lessen the load trying to keep the engine from stalling when it's dying.
If there IS fuel in the bowl on shutdown and the solenoid test light remains lit, that leads me back to airflow. How thoroughly have you checked for partially obstructed, collapsed or restricted air intake hoses?
With a gasoline engine, blocked exhaust lines can cause problem with back pressure. Can that be an issue with diesels?
Completely checked out and looks like brand new parts. Nothing is collapsing on intake and I even disconnected the air flow sensor to alert to you dirty filters.
Exactly on the money. When there are any of these other problems, the engine gives you clues. This is EXACTLY like turning the key off.
We are going in full circles here... That is where I started the discussion thinking it was just that, a defective temp shut off. I was talked out of it quickly.
Not yet, but I know what will happen... They will charge $100 an hour waiting for it to die, then do all that I have done. Is there a computer diagnostic that shows past problems like on cars?
Unless they changed the design of the shutoff solenoid mount in the pump you should be able to remove the shut off solenoid and run the tractor. You won稚 have any safety shut off function nor will the key shut it off. To kill the engine you would have to use a small screw driver to push in the mechanical plunger inside the injection pump. (I suggest familiarizing yourself with this before starting the tractor)
That would completely rule out any electrical issue with shutdown. All safety and engine protection included. If it still shuts down it誕 a mechanical problem. Problem in injection pump, or a restriction in the fuel lines. Likely not air restrictions because it would smoke profusely before it died.
That's an interesting idea. I would have to make a plate or plug to stop oil from coming out, but not too big a deal.
/ JD X749 Dying after 30-45 minutes #116
If it were my tractor, I would try this to totally dismiss the solenoid and ANYTHING that controls said solenoid.
Three strikes and I'm out!
I'm not dismissing the gravity feed, I just haven't had the time between having to cut the grass as well as everything else.
As for "run mode mechanically", I have no idea what that means at all.
/ JD X749 Dying after 30-45 minutes #118
I don't know how the Yanmar fuel solenoid works but on my Perkins it has a rubber tip and is spring loaded. If you kill the power the spring forces it closed. If you remove it diesel will pour onto the ground. I thought that it has been replaced. If it can be removed without causing a diesel leak then that would be worth pursuing. In the end the idea is to try and eliminate everything but the injection pump $$$$. If you can see fuel in the sight glass then the problem must be closer to the engine.
Looking at a picture of the solenoid it looks like a simple pin that pushes in to shut off the fuel (or pushes in to turn on the flow). This tells me that what ever the solenoid pushes is inside the injection pump could also be broken. I tried doing a search for the solenoid but I found two that look like it but one had 2 wires while most had 3. If it does just have two then if it has power when it shuts off then it's not a safety interlock. I remember Mike saying he tested it but I don't remember how. I would try to rig up a light to the connector. If the light stays on when it shuts off then it's not an interlock.
With a 3 wire system you need to find out what the 3rd wire does. I would assume if this is the case that two wires would just be the power when the key is on and and ground. The 3rd wire come from the computer. If the key is turned off the relay would cut positive to one of the two wires. If the computer thinks it needs to shut the engine down it would do something with the 3rd wire (put power on it or turn power off). A simple multimeter would be very helpful to identify the wires and what they are doing. My simple test with a light would still work but you would need two, one for each wire.
With a 3 wire system you could buy a cheap aftermarket solenoid (hopefully not expensive) and remove the wire that goes to the computer from the connector. Try starting the engine. With a multimeter you could measure the voltage coming from the computer. If it's 12v then you could simply connect the 3rd wire on the solenoid to the battery and run it to see if it shuts off. If it's 0 volts then the engine should start with the wire disconnected and again you could run it to see if it dies.
As suggested in post #125.
Well that is a recent post and I agreed to try it on my post number #133.
I am very open to all of these suggestions but do not have unlimited time. Be patient I'm trying to listen to everybody.
/ JD X749 Dying after 30-45 minutes #120
Mike, get to it when you can and let us know what you find....will ya? I hope you figure it out. :drink:
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
