JD X749 Dying after 30-45 minutes
   / JD X749 Dying after 30-45 minutes #163
Thanks Andy, I appreciate it.
Hope it helps. When I first had my X748 I ran it out of fuel.. Needed dealer assistance to get it restarted. Only failure I've had in 10 years was a bad fuel solenoid
   / JD X749 Dying after 30-45 minutes #164
darn, It made so much sense with it being the relay cutting out the hold in voltage only temporarily. Maybe take a solid look at the fuse block that relay is attached to. It may be cracked.
Can you figure out a way to run it with the fuel stop solenoid removed from the machine. Just thinking out loud but is there a spring in the injection pump that returns that fuel stop plunger to the run position.
Yea, we discussed that earlier by plugging the hole (oil will leak out) and inserting a probe to turn the engine off. I was thinking of just rewiring it directly without going through the system, but if there is a problem in the injector pump the problem will still exist.
I called JD today to find if there is a diagnostic port. They said no, but that there is a way they turn the ignition off & on 3 times and check for a blinking light to give a code. I asked if I can come in and try it, but there is a 2 week backlog with no appointments, first come first serve. How's that for running a business?
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
MASSAGE CHAIR (A58214)
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
