JD X749 Dying after 30-45 minutes
/ JD X749 Dying after 30-45 minutes #163
Thanks Andy, I appreciate it.
Hope it helps. When I first had my X748 I ran it out of fuel.. Needed dealer assistance to get it restarted. Only failure I've had in 10 years was a bad fuel solenoid
/ JD X749 Dying after 30-45 minutes #164
darn, It made so much sense with it being the relay cutting out the hold in voltage only temporarily. Maybe take a solid look at the fuse block that relay is attached to. It may be cracked.
Can you figure out a way to run it with the fuel stop solenoid removed from the machine. Just thinking out loud but is there a spring in the injection pump that returns that fuel stop plunger to the run position.
Yea, we discussed that earlier by plugging the hole (oil will leak out) and inserting a probe to turn the engine off. I was thinking of just rewiring it directly without going through the system, but if there is a problem in the injector pump the problem will still exist.
I called JD today to find if there is a diagnostic port. They said no, but that there is a way they turn the ignition off & on 3 times and check for a blinking light to give a code. I asked if I can come in and try it, but there is a 2 week backlog with no appointments, first come first serve. How's that for running a business?
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
UNUSED HYD THUMB (A60432)
UNUSED HYD THUMB...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
Kubota ZG222 (A60462)
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
