Stump Bucket Selection - L3400
/ Stump Bucket Selection - L3400 #1
chaser012001
Kubota L3400
Our property (250ish acres) has started to get overrun with little cedar saplings as well as some other small nuisances that I'm looking at combatting with something a little more efficient, fun, and less taxing on the body than a chainsaw.
I have a L3400 with a LA463 FEL that i'm in the process of converting over to a SSQA which opens my options. One of the first things I'm thinking of getting is a stump bucket to help with the war on cedars as well as dig a couple trenches we need for drainage.
Given the limited size and capacity of the FEL, I'm thinking I should be looking at 'mini' buckets to help keep the weight in check. I think i have it limited down to either a Spartan or a Blue Diamond mini bucket. I like the length and scoop of the Blue Diamond thinking i can get at the roots of some of the larger trees and it's really light at 200lbs. But the stockiness of the Spartan might be less wear and tear in the long run even though its heavier. Since i'm new to this style of tractoring, i figured I'd ask for you all's opinion or if there are other options I should consider. Getting a bulldozer or track hoe are both out of the cards...i have to use what I have.
If it factors in to the decision making, I have a set of pallet forks and I'll be getting a grapple later in the summer.
Specs of the options:
Spartan:
Width:45 in
Height:24 in
Lenght:36 in
Weight:300 lbs
Material Thickness:3/8 in
Cutting Edge:3/4 in x 6 in
BD Mini
42" long
3/8" Steel
Weight 185 lbs
3 replaceable cast teeth
Curved bottom for more leverage
Serrated teeth on sides
Largest in its class
Warranty: 1 year
Made in the USA
To complicate the decision some, there's a good possibility i'll be upgrading tractors in the next couple of years but future plans do not help me now. Thanks in advance!
/ Stump Bucket Selection - L3400 #2
I'll have to start looking at those too. I think the B2650 is pretty comparable to the 3400. I 'think' my lift capacity is around 1200lbs.
/ Stump Bucket Selection - L3400 #4
L3400 wider wheel base and heavier which is BIG help.I had L2800 traded foe B2650 BIG difference doing a project as such.
/ Stump Bucket Selection - L3400 #5
Danuser Intimdator. Dig, rip, grab and go.
Piranha bar works pretty good too. Either one engage about 6” from ground and drive forward pulls the tree out much better than just the loader will lift.
/ Stump Bucket Selection - L3400 #6
For your drainage ditch(es) look at a middle buster/potato plow/single plow. The ditch could be dug with a stump bucket, but a major time investment!
/ Stump Bucket Selection - L3400 #7
The length of the stump bucket is the key parameter.
L3400 hydraulics are too limited to overcome negative leverage of buckets 36" or 42" long.
Piranha bar works pretty good too. Either one engage about 6 from ground and drive forward pulls the tree out much better than just the loader will lift.
A more practical attachment for removing saplings with a light tractor.
VIDEOS: Piranha Tooth Bar - YouTube
Thank you all for the suggestions. Sounds like a Piranha is a good place to start. Luckily I had ordered one already last week. I had been stalking the forum for awhile and it seemed that was the go to for a tooth bar.
I'll give that a shot and see how it goes. I think the Danuser might be a tad out of the ol' budget at this moment.
As for the ditches, I have a box blade that I angle hard to break in that seems to work ok. I thought a stump bucket might be a little more effective since our Missouri soil is littered with rocks.
/ Stump Bucket Selection - L3400 #9
I have a L3700 which is basically the same tractor as yours. Is a backhoe out of the question ? The 463 loader is not particularly strong and pulling anything larger than 4" will be a real challenge.
/ Stump Bucket Selection - L3400 #10
Be prepared to wait a while for the piranha toothbar, i ordered one middle to late march and was early june recieving it. Youll be very happy once it arrives though, total game change in how well the bucket digs and cuts. My l3901 can cut 3 inch sugar gums clean and with work can go after 5 inch trees as well.
I wouldnt necessarily call it out of the question. I have been keeping my eyes out for a B90X but the price on them is tough to justify at the moment. If I were going that route, I could almost justify finding an old Case 580 or something out there since it wouldnt be much more money than a new hoe for the 3400 from what I've seen.
/ Stump Bucket Selection - L3400 #12
What size Are the cedar saplings ? Most could probably be cut with a rotary cutter if they are small. i have hundreds of them on our property as well , the pirahna bar will take out small ones . I can push over and pop out of the ground ones 6 to 8 inch in diameter. but it does leave a hole.
I've chewed some of them up with the brush hog. I'd be targeting the ones in the 2" - 8" diameter range. I have a good idea of the limits of the tractor and i think anything past that, with my current tools, would probably be pushing my luck. Luckily the majority of them are those little annoying ones though. I'm going to try and get after them with that piranha bar when it comes which, by the sounds of it, may be the end of the summer which is kind of a bummer. On the bright side, fall is going to be FUN!
/ Stump Bucket Selection - L3400 #14
The BH 75 or 77 is what fits your tractor. The 90 won't. Another option is renting a mini x for a weekend. That would make quick work of 4-5" stumps.
/ Stump Bucket Selection - L3400 #15
Given the limited size and capacity of the FEL, I'm thinking I should be looking at 'mini' buckets to help keep the weight in check. I think i have it limited down to either a Spartan or a Blue Diamond mini bucket. -----------------------------------------------
If you buy a mini stump bucket you will have to convert it to fit your SSQA.
Mini QA dimensions:
SSQA dimensions:
/ Stump Bucket Selection - L3400 #16
A Danuser intimidator is an amazing puller. I had one on a 95 Kubota CTL and it would pull 6” trees and quickly dig out a lot bigger ones. But that puller weighs like 650 pounds. It’s going to be pretty useless on the OPs small tractor.
/ Stump Bucket Selection - L3400 #17
A Danuser intimidator is an amazingly puller. I had one on a 95 Kubota CTL and would pull 6” trees and quickly dig out a lot bigger ones. But that puller weighs like 650 pounds. It’s going to be pretty useless on the OPs small tractor.
It’s shown on a B26 probably less lift than the OP’s tractor but still vary handy getting to and pulling the small stuff. Cedar saplings/trees are tougher type of vegetation to remove. Being able to dig, break roots and then clamp and drive forward can rip out impressive stuff. Hook to the M59 really impressive.
/ Stump Bucket Selection - L3400 #18
What part of MO? I am in Southeast MO.
We're in the Steelville area.
/ Stump Bucket Selection - L3400 #20
Very pretty area of the state. It has been a few years since I have traveled through there. Many many years ago we camped and did some floating and fishing in the area.
Sorry as far as soil conditions, I have no clue. I do know you have plenty of hills, be safe!
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
Tube Line Manure Spreader Nitro 275RS (A63688)
Tube Line Manure...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
