Home-made attachments...
/ Home-made attachments... #281
YES-TPH- THREE POINT HITCH---SORRY. --IT CAN, AND IT HAS BE USED ON THE KIOTI. BUT I WOULD LIKE A TPH MOWER FOR MOWING AROUND A POND, BACK UP TO EDGE AND DROP IT AND DRIVE OUT. ALSO THE TIRES ARE NOT LOADED, SO WOULD USE IT FOR BALLAST IF NEEDED. ALSO THE DRAW BAR ON THE KIOTI IS LOWER THAN ON THE JD--JOHN DEERE-- PUTTING THE FRONT OF THE MOWER PRETTY LOW. I DON'T DO A LOT OF MOWING SO I COULD PICK UP AN OLDER MOWER, BUT THE KING KUTTER HAS AN 80 HORSE POWER GEAR BOX, A SLIP CLUTCH AND I JUST WENT THROUGH IT LAST WINTER. IT'S IN VERY GOOD SHAPE. I WOULD LIKE TO HANG ONTO IT AND I DON'T WANT TWO.
THANKS FOR YOUR RESPONSE.
/ Home-made attachments... #282
Darn! I wanted to see a mower that needed a Toilet Paper Holder. :(
Bruce
/ Home-made attachments... #283
Bruce
Are you looking for new ways to store all the toilet paper you bought during the pandemic? :laughing:
/ Home-made attachments... #284
I TOOK THE TOOL BOX OUT FROM UNDER THE STEP, AND INSTALLED A TPH---TOILET PAPER HANDLER. I REWIRED THE FRONT HYDRAULICS SO WHEN I PUSH THE BUTTON, IT UNROLLS AUTOMATICALLY. EACH TIME I PUSH THE BUTTON IT UNROLLS ABOUT A ROLL AND A HALF. TOO MUCH FOR ONE----DISCHARGE. STILL A WORK IN PROGRESS. I WAS GOING TO PUT IT ON THE MOWER NEXT TO THE SEAT, BUT DON'T ALWAYS HAVE THE MOWER ON. SORRY NO PICS THEY WOULD LET ME POST.
/ Home-made attachments... #286
I think that we can envision it, and that's enough. :laughing: :cool: :cool2:
As far as converting your tagalong; it seems like buying something like this King Kutter Carry All, Model CA | Northern Tool and attaching it to the mower would be the easiest. It might still require some modification but the advantage is that you could take it off and use it for other applications if you wanted to.
/ Home-made attachments... #288
I'VE THOUGHT ABOUT BUILDING SOMETHING LIKE THAT, ALL I WOULD HAVE TO DO IS REMOVE THE TOUNG FROM THE MOWER.
/ Home-made attachments... #289
This is a home-made attachment to go with the T-paper roles
/ Home-made attachments... #290
I love to DIY!
My cab is DIY
Heater is DIY
3 pt weight is DIY
Snow plow DIY
Camera DIY
LED lighting DIY
Snow blower rotation is DIY
Radio is DIY
Strobe is DIY
As soon as all the snow is gone I'll take a few photos that might ignite some ideas for you all.
/ Home-made attachments... #291
I love to DIY!
My cab is DIY
Heater is DIY
3 pt weight is DIY
Snow plow DIY
Camera DIY
LED lighting DIY
Radio is DIY
Strobe is DIY
Yes, please do share, even from up north Canada. Over here we get plenty of Canadian cold fronts out of Alberta. :)
/ Home-made attachments... #292
Pin on quick attach for the loader
Grapple bucket
Core aerator
Backhoe
Leaf vac
/ Home-made attachments... #293
I didn't make this but I recently purchased this after looking for a ground driven sander I can use on my long ( 1200') gravel driveway in upstate NY
/ Home-made attachments... #294
Keep 'em coming...
/ Home-made attachments... #295
I made a rear loader for my old Ford 2000, from a TSC pond scoop and lift boom. It was more effective than a factory front loader on that 2wd tractor (other than a stiff neck) because it didn't have the traction issue.
A front loader on a 2wd tractor causes the tractor to loose traction when it is loaded, but the loaded rear loader increases traction. That makes it a lot easier to break material out of a hard pile on soft ground.
I hooked the lift boom to the top link position on the scoop, and made (2) lower link extensions from 4" x 1/4" angle iron (approximately 5 ft long). I also used a pair of TSC lower link stabilizers with it to keep from bending the Ford's lower links when I stabbed the scoop into a pile.
That rear loader worked great for loading a manure spreader, but I also used it to load a dump truck with dirt and stone. The best part was the cost (free), since I already had all the components to make it.
You need a decent ammount of 3 point lift capacity to use it. My Ford 8n, could just barely lift the empty scoop, but the 2000 would lift it heaping full.
I only got rid of it after getting a 4wd tractor with a front loader (no traction issue there), and no stiff neck.
/ Home-made attachments... #296
Its not as fancy as many things on here, but here is my tool bar on my small garden tractor. The frame is made of old scaffold pole. There are two small pegs welded to the top of the bottom cross member. The idea being, a chain can be quickly turned one turn around the bar, then a link simply dropped between the pins. I use it for pulling firewood and pulling up small trees and hedges. I added an electric winch and a standard ball hitch for pulling a small trailer. Everything works well
/ Home-made attachments... #297
For mucking horse stalls we need to move about 5-6 yards of material from one end of the property to the other daily (about 1/2 a mile). I made an FEL basket/bucket clad with rubber conveyor belting remnants from a local quarry. We load via muck buckets or wheelbarrows so it doesnt have to withstand digging forces.
On the 3pt is a dumping box, based off of the TSC carry-all frame and scrap metal on hand. A board fits in across the back that is easily removed for dumping.
/ Home-made attachments... #298
Log grapple, carry all with hydraulic dump.
/ Home-made attachments... #299
Adjustable forks with hydraulic thumb.
/ Home-made attachments... #300
You need a decent amount of 3 point lift capacity to use it. My Ford 8n, could just barely lift the empty scoop, but the 2000 would lift it heaping full.
Could you post a few pixs please. :)
Loaders are so pricey now. The OE for my machine when I got it was just over $2,500. It's now about DOUBLE the price.
I've been looking at RELs for about 2 years now. I may have an idea.
This one from the 90s till about 2011 was $700 without hydraulic top-link and $950 with hydraulic top-link. The company is gone now.
The bucket is made by Swisher as a FEL for ATVs and UTVs. It was then modified as a 3PT REL by
DP Equipment in the southeast.
There are plans out on the internet I had found to utilize the Swisher bucket for SCUTs and CUTs as FEL or REL applications. Just doing a little change-up on the Swisher mounting makes it doable as a REL.
Here's the plans.
With the finished setup in the very last image, the bucket can now work either as a FEL or a REL. :)
As a FEL
As a REL
I could do a hydraulic top-link to dump or utilize an electric variable positional linear actuator to hinge the bucket to dump at any control angle up to and even curling the bucket. :)
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
2006 Isuzu NPR-HD Crew Cab Landscape Dump Truck (A61568)
2006 Isuzu NPR-HD...
2014 CM TRAILER ENCOLSED CARGO TRAILER (A60736)
2014 CM TRAILER...
