Buying Advice Need a zero turn that doesn't exist?
/ Need a zero turn that doesn't exist? #43
Something I used to do was burn off fields instead of cut. I used a propane torch to burn a path all around area about 5ft wide, a little at a time. Then a day with no wind burn the field. It always came back better.
The Cub RZT I like on steep because it's much lighter than my Z-Force. I shorted out seat safety switch (do that at your decision) so I can shift my weight around.
I would never want to cut across a steep hill.
/ Need a zero turn that doesn't exist? #45
that's mowing sideways.. mowing up and down is a bit more..
My Cub must be magical then, always with turf tires back, smooth ones on front. I mow this fence line sideways no problem. 20200618_121058.jpg
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
832640 (A61166)
832640 (A61166)
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
Vertical Steel Well Tank (A61570)
Vertical Steel...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
