Buying Advice Need a zero turn that doesn't exist?
/ Need a zero turn that doesn't exist? #43
Something I used to do was burn off fields instead of cut. I used a propane torch to burn a path all around area about 5ft wide, a little at a time. Then a day with no wind burn the field. It always came back better.
The Cub RZT I like on steep because it's much lighter than my Z-Force. I shorted out seat safety switch (do that at your decision) so I can shift my weight around.
I would never want to cut across a steep hill.
/ Need a zero turn that doesn't exist? #45
that's mowing sideways.. mowing up and down is a bit more..
My Cub must be magical then, always with turf tires back, smooth ones on front. I mow this fence line sideways no problem. 20200618_121058.jpg
New/Unused Wolverine Mini Skid Steer 3 in 1 Bucket (A61166)
New/Unused...
(2) 18.4-38 SNAP ON DUALS W/HARDWARE (A62131)
(2) 18.4-38 SNAP...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
UNUSED JOHN DEERE STRIP-TILL WHEEL ASSIST (A62131)
UNUSED JOHN DEERE...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
