Buying Advice Need a zero turn that doesn't exist?
/ Need a zero turn that doesn't exist? #43
Something I used to do was burn off fields instead of cut. I used a propane torch to burn a path all around area about 5ft wide, a little at a time. Then a day with no wind burn the field. It always came back better.
The Cub RZT I like on steep because it's much lighter than my Z-Force. I shorted out seat safety switch (do that at your decision) so I can shift my weight around.
I would never want to cut across a steep hill.
/ Need a zero turn that doesn't exist? #45
that's mowing sideways.. mowing up and down is a bit more..
My Cub must be magical then, always with turf tires back, smooth ones on front. I mow this fence line sideways no problem. 20200618_121058.jpg
Jack Daniels Mini Decorative Truck (A61569)
Jack Daniels Mini...
2016 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Truck (A61568)
2016 Globe Trailer...
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A63118)
2025 Wacker Neuson...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
