COVID-19 DIY Build Time
/ COVID-19 DIY Build Time #21
Very good idea!!!
/ COVID-19 DIY Build Time #23
I know it cooks the same, as I cook ribeyes for 6 minutes on each side, the minutes are exactly the same,,
the steaks get done the same amount (medium rare) the only thing different is that I save 2/3 of the charcoal.
The only negative is that you CAN NOT light extra charcoal,, the cooking temp will get REALLY WAY TOO HOT.
Actually, I think I could even use less charcoal than I now use,, I have only used the ring about 15 times.
I consider this ring a real success.
OH, by the way, my ring is stainless steel sheet, that is what I had in the shop,,,
I think the ring could be 3 inches, or 4 inches, or 5 inches wide, and still work the same way,,
so the width is not critical, if you make one, use what you have,,,
When my daughter and her family comes over, and I gotta cook more food,
I simply lift the ring out, and use more area of the grill,, no permanent change was made to the grill.
But NOT galvanized steel, and there are several other metals that are problematic. Yeah, I know that Tractor Supply sells galvanized fire rings, but zinc (galvanized) fumes are poisonous. Metal fume fever - Wikipedia
We need more COVID caused projects!!
Since my daughter is kinda trapped at home with her 4 children (the oldest is age 10) , they decided a cottage might be nice as a place to go for the day.
A small (~800 sq ft ? ) cottage, with 26 acres came up for sale,, my daughter bought it!! They now have PLENTY of space for the kids to run,,,
No furniture was left behind, so they are trying to add some furnishings as inexpensive as possible.
I decided to whip up a picnic table, and a bench,, these can be used outside, or on the screened in porch,,
The picnic table is welded, but, it needs further cleanup before paint.
I painted the bench this weekend,, the oil based paint will need a week or so to harden,, I did add hardener to the paint,,
hardener REALLY makes the low cost oil base paint level nicely, and the hardener seems to make the paint shine.
This paint was applied with an old 2 inch brush that I found in the shed,, as opposed to spraying.
The bench will have two pieces of composite decking board as the seat, the boards are 5 feet long, 5 1/2" wide.
The boards are tan.
This is it,, so far,, it is a new design I whipped up.
Everyone seems to like the design,, or maybe they are just being nice? :eek: `~ :confused:
The round parts are solid steel bar, 1 inch,, and 1 1/2 inch ,, that gives the bench a nice weight to it,, and it will be much less likely to turn over.
I had some paint left over that had hardener in it, so I applied the extra paint to the sawhorses,,, :laughing:
/ COVID-19 DIY Build Time #25
Big part my faith is leaving rocks where dey are. God made de rock he put it where he wanted it, who am I to move it?
/ COVID-19 DIY Build Time #26
Nice job. Looks like a fun project! With an underslung plow build underway and waiting on hydraulic parts, I decided to build a carryall for a little bit of counter weight and to carry my snowblower for a few sidewalk jobs in the neighborhood. Just used some steel ninjas laying around and most of the lumber came from a Home Depot scrap bin for pennies on the dollar.
The boards are tan.
Great looking carryall!! I have never built one, because I use a 4X8 trailer,, for me, it is more convenient if I need to leave it loaded,,
I never take the trailer anywhere that turning around is an issue,, touring the neighborhood would not work,, pulling a trailer,,, :laughing:
/ COVID-19 DIY Build Time #28
What type of paint did you use for your project? I have aREALLY old gallon of Kubota orange Magic Paint. Bought it to cover some implements long ago and never ended up using it. Also used the hardener. I’ve only dealt with automotive paints and I hear this Magic stuff never dries and fades bad. This is a carryall and I’m not utterly concerned but I have to say, brush application went well until I applied a second coat too early. Again, carry all... I don’t care but it still came out nice.
What type of paint did you use for your project? I have aREALLY old gallon of Kubota orange Magic Paint. Bought it to cover some implements long ago and never ended up using it. Also used the hardener. I致e only dealt with automotive paints and I hear this Magic stuff never dries and fades bad. This is a carryall and I知 not utterly concerned but I have to say, brush application went well until I applied a second coat too early. Again, carry all... I don稚 care but it still came out nice.
The hardener must be mixed in a FULL 30 minutes before you start applying,, FULL 30 minutes
If you mix, then apply, the hardener acts like it is not even there.
The hardener keeps it glossy, and seems to maintain color better.
The paint I used was the stuff TSC used to carry before Majic Paint. I think it is Valspar.
I normally spray, but, it was too cold, and the brush paint is good enough for a bench.
This is the same paint and hardener, except sprayed.
Well, one board was about a foot longer than the other, rather than just cut the board off,,,,
I cut it into three pieces, drilled a 3 inch hole in one,, and made it into a built-in water bottle holder.
Then, I bolted the boards to the frame with stainless carriage bolts.
This is the picnic table I built for my daughter a year or so ago,, same boards, same paint,,
they kinda match,, I think,,
Still building,, my daughter bought another property,, with a cottage,,
the picnic table left behind is totally rotted,, so time to build,,
After welding, I got some paint on it today..
The picnic table will get composite wood, kinda like the bench,,
I added a wide wheel,, so the table can be moved like a wheelbarrow,,
I have built these benches and picnic tables with the seats at 22 inches high.
They are a very comfortable height,,
Why does everyone build picnic tables so low??
My daughter mentioned that she wished there was a sideboard table so the food did not take up the picnic table when they eat outside,,
I figured it would be easier to extend this table, as compared to making a separate table,
so, I built a couple extension brackets, and picked some longer composite wood.
I finished bolting the boards on it today,,
It is real easy to move with the wheel, and almost effortless to rotate 90 degrees, as it will pivot on the wheel.
2025 Future FT-46 Hydraulic Drum Mulcher Skid Steer Attachment (A61572)
2025 Future FT-46...
2006 Volvo VNM S/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM S/A...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
2009 CATERPILLAR D6KXL CRAWLER DOZER (A64279)
2009 CATERPILLAR...
(2) 17.5L-24 TIRES & 8 LUG RIMS (A63291)
(2) 17.5L-24 TIRES...
