Need help identifying the year/model of this NH tractor and getting it to start.
   / Need help identifying the year/model of this NH tractor and getting it to start.
It sounds like it would be a good idea to replace the hydraulic fluid and filter.
I'm planning on it. Trying to get part numbers together so I can start ordering everything.
I'd like to do a hydraulic fluid flush/filter change, an oil change, air filter change, fuel filter change, and I'm not entirely sure on the hydrostatic fluid if that can be flushed/changed without affecting the performance or operation of the transmission.
   / Need help identifying the year/model of this NH tractor and getting it to start. #42
The 2 neutrual position points are very finicky on those tractors if it won't start in 1 then try the other . Underneath the lever is a N safty switch make shure when you put it in N the N safety switch is fully engaged .There is an adjustment screw to move it back and forth to fully engage switch . The screws can come loose or the adjustment can be out of wack from normal wear and tear.:drink:
   / Need help identifying the year/model of this NH tractor and getting it to start. #43
   / Need help identifying the year/model of this NH tractor and getting it to start. #46
That link doesn't list any D models, or mention anything about a hydrostatic transmission. It may just be for the non Deluxe models.
It shows the Hydrostatic Filter (HST Filter)
   / Need help identifying the year/model of this NH tractor and getting it to start. #47
Filters and Lube Chart - New Holland Ag & Compact Tractors - New Holland Rochester
Filters and Lube Chart New Holland Ag & Compact Tractors
MODEL:
TC29D
DESCRIPTION:
SERIES:
ENGINE:
15W40 4.2-QT (4L)
REAR AXLE & TRANSMISSION (INCLUDES TRACTOR HYDRAULICS):
134D 8.8-Gal (33.3L
TRANSMISSION (IF SEPARATE):
Included In Rear Axle
FRONT AXLE, HUBS & DIFFERENTIAL EACH FWD ONLY:
134D 1.5-QT (1.4L) Axle 0.85-QT (0.8L) Each Hub
POWER STEERING:
134D 1.7-QT (1.6L)
COOLANT:
1.06-Gal (4.L) 4.2-QT (4.L)
MISC:
COOLANT FILTER:
OIL FILTER:
84475542
FUEL FILTER:
87300039
ENGINE AIR FILTER:
87682998 Outer 84539215 Inner
HYDRAULIC FILTER:
84475483 & Hydro SBA340500990
CABIN AIR FILTER:
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
FUEL TANK W/2 STANDS (A55745)
FUEL TANK W/2...
UNUSED FUTURE 19" EXCAVATOR RAKE (A52706)
UNUSED FUTURE 19"...
Titan 84in Box Blade with Rippers (A54865)
Titan 84in Box...
UNUSED FUTURE VR72 - 72" HYD VIBRATORY ROLLER (A52706)
UNUSED FUTURE VR72...
