Need help identifying the year/model of this NH tractor and getting it to start.
   / Need help identifying the year/model of this NH tractor and getting it to start.
It sounds like it would be a good idea to replace the hydraulic fluid and filter.
I'm planning on it. Trying to get part numbers together so I can start ordering everything.
I'd like to do a hydraulic fluid flush/filter change, an oil change, air filter change, fuel filter change, and I'm not entirely sure on the hydrostatic fluid if that can be flushed/changed without affecting the performance or operation of the transmission.
   / Need help identifying the year/model of this NH tractor and getting it to start. #42
The 2 neutrual position points are very finicky on those tractors if it won't start in 1 then try the other . Underneath the lever is a N safty switch make shure when you put it in N the N safety switch is fully engaged .There is an adjustment screw to move it back and forth to fully engage switch . The screws can come loose or the adjustment can be out of wack from normal wear and tear.:drink:
   / Need help identifying the year/model of this NH tractor and getting it to start. #43
   / Need help identifying the year/model of this NH tractor and getting it to start. #46
That link doesn't list any D models, or mention anything about a hydrostatic transmission. It may just be for the non Deluxe models.
It shows the Hydrostatic Filter (HST Filter)
   / Need help identifying the year/model of this NH tractor and getting it to start. #47
Filters and Lube Chart - New Holland Ag & Compact Tractors - New Holland Rochester
Filters and Lube Chart New Holland Ag & Compact Tractors
MODEL:
TC29D
DESCRIPTION:
SERIES:
ENGINE:
15W40 4.2-QT (4L)
REAR AXLE & TRANSMISSION (INCLUDES TRACTOR HYDRAULICS):
134D 8.8-Gal (33.3L
TRANSMISSION (IF SEPARATE):
Included In Rear Axle
FRONT AXLE, HUBS & DIFFERENTIAL EACH FWD ONLY:
134D 1.5-QT (1.4L) Axle 0.85-QT (0.8L) Each Hub
POWER STEERING:
134D 1.7-QT (1.6L)
COOLANT:
1.06-Gal (4.L) 4.2-QT (4.L)
MISC:
COOLANT FILTER:
OIL FILTER:
84475542
FUEL FILTER:
87300039
ENGINE AIR FILTER:
87682998 Outer 84539215 Inner
HYDRAULIC FILTER:
84475483 & Hydro SBA340500990
CABIN AIR FILTER:
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
2019 GENIE S-45 BOOM LIFT (A52709)
2019 GENIE S-45...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A55973)
2019 John Deere...
