Buying Advice Anybody buy/install or review an atvcabs cab for a BX? (2370/2380)
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #1
Yota_85
Western Mass
Kioti DK35se
Link here:
Kubota BX238 Tractor Cab - Steel Enclosure - ATV CABS LLC
Curious if anyone has any info on them.
I like the idea that they can be installed & removed fairly easily.
And that they are hard cabs, with decent options (Wipers, glass winders, heater option)
I like the new factory Kubota BX2380 cab (Curtis really) but it's permanent. Only the doors come off.
Don't wanna deal with a cab while mowing under trees in summer.
So if you have one:
Do the winders fog up without a heater in winter?
Does it seem well built?
How does it hold up from several assemblings/disassemblings?
Did you get some of the options? (Wipers, heater, glass side opening doors)
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #2
Yota,
I have a BX2370 (same basic machine as yours) and i have an Original Tractor Cab cab on mine in the winter and its awesome!! I had one of their cabs on my Wheelhorse tractor before this. It痴 easy to put on and take off! I have the glass windshield with a wiper and lights. I am a big weather wimp and I find I do NOT need heat in the cab. I wear a light jacket and Im fine, you get heat from the transmission and engine.
I think it was about $1000 delivered to my door!
PM me for pictures or drop by next November and Ill give you the tour! Im halfway B/T Boston and Plymouth
Cheers,
BN
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #4
We have a 2009ish BX2660 with a Curtis cab and have been happy with it other than the Velcro holding the back on has fallen off (replaced it with snaps).
The doors, windshield and back come off in the spring and it runs around all summer mowing with a shade canopy.
We prune or mulch the trees so that they don't hit the cab.
Aaron Z
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #5
SeaBee,
I don’t have a BH on my machine, but the rear panel is removable so I guess you could use a Backhoe with it. I had my other cab on my Wheeelhorse fir 21 years and it worked Mint!
I should add there the installation of my cab required NO new holes or modifications to the tractor! It takes me about 1 hour to install in the Fall and about 1/2 in the Spring to remove it. I do have a ceiling hoist in the garage which makes it easier.
Cheers,
BN
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #6
Meant to mention that we had an Original Tractor Cab on a Cub Cadet 3000 series where I worked a while back, it was on the snowblower tractor, worked ok, but was a little finicky to put on and it was nowhere near as nice as the Curtis on the Kubota (granted, the OTC was ~$800 with a glass windshield vs significantly more for the Curtis).
Aaron Z
Are they made so you can use the BH with them on?Ron
They have 2 models. One for the 1880/2380/2680 and one for the 23S. Guess it's different because of the different ROPS
Byrd,Do you find the windows fog up, without a defroster/heat in cab?The ATVCabs cab does look nice. And considerably cheaper (nearly $1k) than the factory cab.
The Curtis "advantage" cab does looks appealing at $3400 with heat & front wiper.But it's permanent, not really fully removable for summer. Plus there's the installation cost to figure in.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #10
Yota,
I have a BX2370 (same basic machine as yours) and i have an Original Tractor Cab cab on mine in the winter and its awesome!! I had one of their cabs on my Wheelhorse tractor before this. Itç—´ easy to put on and take off! I have the glass windshield with a wiper and lights. I am a big weather wimp and I find I do NOT need heat in the cab. I wear a light jacket and Im fine, you get heat from the transmission and engine.
I have this on my BX1880 as well, same as above. I have the manual wiper, glass windshield. No fogging issues, and although I got a free electric heater with mine, I haven't felt the need to install it. First time install takes a bit, however you can take it on/off pretty quick in sections. Its really nice to be out of the wind and blowing snow.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #11
Link here:
So if you have one:
What did you end up deciding? I'm in exactly the same boat and I have the same considerations about the permanent cab and was looking at the ATVCabs.net for the same reason - appears relatively easy on / easy off. Appreciate any further information you found out or to hear what you ended up deciding and how that's going.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #12
I’m in the market for a cab for my BX2670, as well. I’ve looked into all. Frankly, I think the ATV cab with some realistic options, was like $5800. That’s more than any cab I looked at. I figured I can buy several original tractor cabs for the cost of any hard cab, and for a few months of use, it should be fine. If I bought a new BX2680 tomorrow, I’d consider the factory cab, but only if I could remove all windows and doors.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #13
Let me throw something out there from personal experience. In late 2012 I built a cab for the L3200 I had at the time. I made it in sections for easier off and on. It only came off the first Summer. After that, I just lifted the doors off. Running one of those 2-speed "bus driver" fans kept the doorless tractor more comfortable in the heat than when it was topless.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #14
That mirrors our experience with the Curtis cab on our bx2660.
During the summer we take off the doors, the windshield and the soft back, leaving the top and the frame.
In my opinion that keeps you cooler than if we were to take the whole thing off because it gives you a sun shade.
The only downside is that you have to trim around the edges better to clear the cab.
Aaron Z
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #15
So I bought a BX2380 without the cab. I love the ease of on/off with the ATVcabs brand, but frankly, the mid to top if the line Curtis or factory Curtis are worth ALOT more for the minimum cost over the ATV. Add wiper, sliding glass, and heater, and the ATV is about $8k. The best factory Curtis is less.
I’m still thinking about the Original. Almost hit “Purchase” in my cart 3x. Now that I have a dedicated zero for mowing, the tractor is for bagging, loader work, and snow removal. I have no need to remove the full cab. I just can’t see spending $8k or $5k. The ATV is plexiglass windows, and I’ll bet a fortune to replace with the size and rear bent window. I think they likely don’t sell many due to the cost with minimal options over a factory cab. I’d consider at $3500 in comparison to the mid-grade Curtis, but that’s it.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #16
My BX2230 has the Sims cab on it. Door and right side are clear vinyl and the door has a steel frame. Both come off for the summer. Front and back windows are glass and stay in all the time. Jon
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #17
Thanks for the recommendation. The Sims Yukon for the 70-Series is $4,500 with soft doors. Not much savings over the base ATV, which is removed in minutes. Sims doesn’t show an 80-Series yet. I’ll have to contact them.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #18
Apologize if this is off topic, I am not sure if you are considering soft cabs or not. I ended up getting the "Original Tractor Cab" for my BX1880 because it was significantly less money and I need it only for clearing snow in the winter. It has worked out great for me. It comes flat packed so the initial install takes some time but when you remove it, you don't have to completely disassemble it. I take the frame off in like 3 sections. I got the glass window, and the manual wiper. Let me know if you have other specific questions on it.
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #19
Thanks, atitus74. Have you found the manual wiper sufficient? I’ve often thought the electric to be a perk I’ll pay for, but rarely use. However, I face west, nothing around, and expect the blowing snow melting on the windshield to be a pain and requiring me to flip wiper on/off to avoid chattering.
Have you considered screen doors in summer for $350?
   / Anybody buy/install or review an atvcabs cab for a BX? (2370/2380) #20
In the summer I'm happy to have it off. It doesn't take me too long to mow, so I don't feel the need for the canopy or doors. The manual wiper works well. They included a ceramic electric heater but I intentionally don't use it. I just wear a jacket. Its great to be out of the elements, and since the inside of the cab is not heated, it really doesn't fog or have snow stuck all over it.
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
