Portable Dump Trailer Jack
/ Portable Dump Trailer Jack #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
My SUV jack cant pickup my loaded dump trailer. What do you guys use for a portable trailer jack for use on the road? How do you store it ?
/ Portable Dump Trailer Jack #2
A bottle jack is your strongest most compact option. An aluminum floor jack is a lot easier to use but probably too big to keep in your vehicle.
/ Portable Dump Trailer Jack #3
I keep a bottle jack that has an integrated jack stand along with a pretty wide footprint with me on all road trips--Along with a Dewalt 20v impact wrench
awesome guys. Any recommendation for a bottle jack?
/ Portable Dump Trailer Jack #5
I actually have a hydraulic leg on my BIG off-road dump trailer. Came off a Hyab crane. I put a valve in circuit that switches from the hoist to the tongue jack. Makes hookup much simpler.
DSC00172.JPG Realized I didn't have a picture of this on file and thought it might stir some creative juices.
Tractor has to do double duty pulling this trailer, and pulling a Harley Rake, so it was necessary for me to make the hookup as painless as possible. Being able to raise and lower the jack from the drivers seat is a definite plus.
When connected, a pin is pulled and the jack rotated out of the way and pinned up.
i am getting a hydraulic jack for the tounge next time. they seem so easy!
/ Portable Dump Trailer Jack #7
For infrequently used stuff I find Harbor Freight entirely adequate. With most HF stuff that has a weight rating I get stuff rated for double my max expected load though.
/ Portable Dump Trailer Jack #8
Hydraulic bottle jacks work fine. Be real careful that you buy a jack that will fit under the axle or jacking point when you have a flat. If you have leaf springs and they run under the axle then check the height of the jack under the flat part of the spring section under the axle. If your jacking directly on the axle its round shape can cause a issue. I keep a welded up assembly of a right angle iron that is on top of a pipe coupling. The angle iron is upside down so that it fits to the bottom of the axle and the jack goes up into the pipe coupling. Stops slipping around issues. Bottle jacks are available in really short options.
You just saved me from making a huge mistake. Thx
/ Portable Dump Trailer Jack #10
If you are at the side of the road and your flat tire is on the passenger side, you've probably got a little drop off on the shoulder so you have even less clearance than you think. I had to tow a heavy trailer with a flat tire for a ways to get enough clearance to put the jack under it. (I had a standard size 8 ton HF jack) Be sure to get the shorty jack and one that is rated for way more than you need because it will also be easier to pump it on the side of the road.
I made my axle jack adapter similarly. 2 pieces of angle iron welded to a flat plate (I checked spacing so the flat plate would contact the axle also) and I used a really big washer on the other side instead of the pipe, but I like the pipe idea better. Use what you have.
/ Portable Dump Trailer Jack #11
Hmm, good point about on the side of the road. It’s frustrating when the jack goes down into the ground and the Trailor sets there. Sometimes need room to put something under the jack to keep it from sinking.
It depends on spring setups but often times on Trailors with 2 or more axles you can put blocks down and pull the good tire up onto the blocks (on the side with the flat). Fix the Trailor and truck where it will not roll and you can change tires without messing with the jack.
/ Portable Dump Trailer Jack #12
I just carry a few short 2 x 6痴 so I can drive the flat tire up on one or more of them to get the axle high enough to get the jack under.
/ Portable Dump Trailer Jack #13
Can you post a picture of your angle iron/pipe coupling device? I壇 like to steal this idea
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
RoadTec RP190 (A63689)
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2020 Crown Concrete Mixer (A65579)
2020 Crown...
