Driveway Gravel
/ Driveway Gravel #41
I bought ~21 tons delivered in Northern NC (near Mt. Airy) a couple months ago for $495. I do need something with rock dust though so I can stop the weeds from growing through it.
/ Driveway Gravel #42
I bought 16 yards of bitcon (mix of crushed asphalt and concrete) to rejuvenate 360' of 10' wide gravel driveway recently. It was enough to apply a nice 1.0-2.5" layer on most of it. Maybe not quite as thick as I believe it is, but close.
Rob
/ Driveway Gravel #43
A local company here charges $300 for 16 tons.
Yea but they “load 16 tons and what do you get,
another day older and deeper in debt”.
Sorry, couldn’t resist that🤭
/ Driveway Gravel #44
We are in the process of putting 24, 15 ton loads of 1" minus on our road. They are running us $333 per load delivered, graded and rolled. The contractor is a relative of one of my neighbors so I hope we're getting the friends and family price.
/ Driveway Gravel #45
Sorry, couldn’t resist that��
Not to mention "owing your soul to the company store" :)
/ Driveway Gravel #46
I think that is a good price for being installed. I pay $250 for 15 tons just dropped... they will not even tailgate spread it.
/ Driveway Gravel #47
How far are they having to truck it? Here the quarry is about 10 miles away. I can buy 1” minus for $9 per ton and if you’re paying to have it trucked that’s about the same rate maybe a little more.
/ Driveway Gravel #48
Call the gravel pit and ask for a trucking company that can drop spread it for you" tailgating".
/ Driveway Gravel #49
$450 a load delivered here in the Denver area for 15 tons of roadbase.
/ Driveway Gravel #50
A lot of this is regional I think.
For instance, here in Maine where I live, you get loads measured in cubic yards, so a wheeler (2 rear axle dump truck) will give you 14 cubic yards for $150, but dumped, and not spread. At a conversion of 3000 pounds per cubic yard, that is 24 tons for $150.
BUT...here what we call "gravel" is also a mixture of sand and rock. It might be run through a screen, but it is out of the bank in the pit. I watch TV shows and what they call "gravel", is what we call "crushed rock". it has no sand in it at all, and is right out of the crusher.
/ Driveway Gravel #51
Around here, crushed rock is gravel, what you refer to with sand in it is generally called bank run (ie: scoop it out of the bank and into the truck).
Aaron Z
/ Driveway Gravel #52
You are not getting 24 tons in a tandem dump truck. By law they are limited to 54,000 lbs. 34k on the tandem and 20k on the front axle. 24 tons is full load for a belly dump or end dump semi.
/ Driveway Gravel #53
I have owned two dump trucks a tandem and a SRW and a couple semis. My tandem dump weighed 20k empty. I could only haul about 15 tons of material without being overweight. Physically I could fit 16 yards in the bed but legally not much over 10 yards of gravel.
/ Driveway Gravel #54
Its different in every state In MA we carry 22 ton on a 10 wheel dump and 24 ton on a tri axle dump...
/ Driveway Gravel #55
Here they’re legal for 74,000 on a tri axel dump.
/ Driveway Gravel #57
Whatever - last estimate I got for 6" layer of pit run down my mile long gravel driveway - $34K to $36K. I stayed with what I had. Pit run around here - nothing larger than 2" and it will go all the way down to sand and silt. Screened material is 25% more expensive. These estimates are 20+ years old also.
/ Driveway Gravel #58
It varies from state to state on state highways and county roads. Anything federally funded (a US RT or Interstate) is covered by federal laws limiting weight. 34000# on tandem axles, 43000# on tri-axles, 18000# on a steer axle (depending on tire width.) Maximum loads depend on number of axles and overall axle spread. We could get about 12 yards on a 5 axle truck, about 32,000#. They just bought some 7 axle trucks that can haul 24 tons or so. We had a set of belly dumps with 7 axles (counting the tractor) that could gross 105,500 but they were the evception, 8 axles for that weight was more common.
Tailgating was the term we used to not set the spreader chains and just dump gradually while on the move, it would typically spread a box of pitrun 10" thick and 50 or so feet long. For a driveway we would set the chains and spread evenly, usually 3 to four inches thick.
Gravel is usually sold by the ton or by the yard, nearly all I dealt with scaled the truck and gave a scale ticket that had the a the truck company and truck number, the weight in and out and net and a time stamp. Any questions, ask to see the scale ticket.
/ Driveway Gravel #59
It's an area where the customer often get's taken advantage of. I learned from a really cheap/astute neighbour to climb up and look what they are delivering. Ask questions. Why is the box only half full? Load restrictions? No one bothers telling the customer that he should wait a month and get better loads. The trucking costs the same. Or will it be a semi or tri-axle? Stuff like that.
I ALWAYS specify, that I expect "GOOD" loads.
/ Driveway Gravel #60
Hopefully at that price it was graded and compacted by a contractor, not just a materials price. Seems way steep to me for materials only.
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
