Moldboard plows
/ Moldboard plows #1
tree grower
Cuttingsville, VT
Ford 1210, Bobcat 742B, John Deere 1050
I have read posts by jeff9366 and farmwithjunk, but still have trouble. I have a Ferguson 16A single bottom plow behind a JD 1050 fwd. The tires are 13.6-28 on 12" rims, and the wheels are set as narrow as possible. It is 37" between inside sidewalls. I raised the left rear tire 8", and adjusted the plow per jeff and farm .. instructions . In practice the plow tracks true and sucks as much as the miserable soil will allow, but the furrows are nearly 2 ft apart. The plow beam is set as far to the right as possible on the offset drawbar, and the stay chains on the bottom links are tight. Rotating the drawbar small amounts just to see what happens doesn't make much difference. BTW, my previous tractor was a Ford 850, and the plow was just as uncooperative. Is it possible that this plow was intended to be used on a particular make and model of tractor? Does my 1050 need to use a specific brand of plow? Any insights are most appreciated.
/ Moldboard plows #2
I have an 18" Pittsburg single bottom moldboard plow. The most difficult adjustment - for me. Adjusting it horizontally so I can track back down the open furrow and create a second furrow the correct spacing from the first. After much time spent making horizontal adjustments - it does pretty well now. But it was not easy.
I could get the appropriate spacing if I didn't mind driving on the turned furrow. I wanted to be able to track back down the opened ditch with the front & rear tire. Also - have the plow open a second furrow the appropriate distance from the first.
For me it was a matter of trial & error. I think my sway links were, initially, too loose. The plow would not track the way it hung when lifted. It would alway pull to the side and leave an unplowed strip.
Trial & error - it was my first experience with a moldboard plow. Perhaps a multi bottom would be easier. You could alway overlap and ensure complete coverage.
/ Moldboard plows #3
A picture from behind would be a big help, with the plow mounted, setting on the ground. Take the picture(s) lining up with the inside of the right rear tire, a few feet back.
The back end of the share, should at the least, line up with the inside of the right rear tire. That way, when that tire is in the furrow, it will cut the next furrows bottom, clean into the previous furrow bottom. If not, it will crowd the plow to the left.
Does that plow have a tail wheel..? The tail wheel should ride against the furrow wall, and help hold it in place.
/ Moldboard plows #4
I'll tell you. Once I got things adjusted - a single bottom MB plow behind a 65 hp tractor is a cutting machine.
/ Moldboard plows #5
I would think the pic needs to be of the plow in the ground,, showing the position the draft arms are forced to by the plow,,
The solution might be simply shortening the right draft arm chain,,,
On my JD 4105, if the draft arm chains are not correct,, the implement will simply walk to the side,,
Even this landscape rake will push the draft arms to the side,,
/ Moldboard plows #7
Just me, but I'm wondering if the plow is too narrow of a total working width for the tractor to drive in the furrow bottom.
Not a expert on plowing, but it'd seem to me that if the total plow working width isn't roughly half the distance between the inside of the rear sidewalls at a minimum a person would run into issues with aligning the rows appropriately ---- with the width of a single share needing to be roughly similar to the tire width so the tire can sit in the furrow bottom (and have firmer soil to grab).
While it wasn't specified, I'm guessing this is a 12" single bottom plow? (just a guess, given the distance between furrows, and the distance between inner sidewalls &tire widths).
To my mind the key with plowing is to get the total draft load of the plow to be inline with the draft line of the tractor, with the spacing of tires being driven by the need to potentially shift where that line is with respect to the tractor --- as well as to position the right tire(s) so it/they can land in the furrow made by the last share on the plow.
If you think of the plow as acting like a sea anchor, where it will pull the tractor into line where the draft load from the plow rudders the tractor into a balance it may make adjusting the plow position easier to understand.
Of course, there's also the option of not having the right wheels in the furrow bottom when plowing, and adjusting the plow accordingly for that......
Again not claiming to be a plowing expert, just making some observations based on my own experiences and thinking through some of the physics/geometry of the situation.....
/ Moldboard plows #9
treegrower, there are a few videos on youtube on these plows. Most likely they are those setting up a single plow also. No idea on the model of the plow or the tractor you are working with but the dimn you give on the tractor tires not a farm tractor so you plow may not work with that width if it is true farm plow. But they do make those plows for garden tractors. What comes to my mind is you have a left hand or the rear plow of a two plow set. Not sure that is possible for the moldboard plows I have seen the plow on the left is bolted to the plow on it's right.
Those plows can be a little tricky to get set up correctly but not really hard. When they are set right they do some pretty work and will lay dirt as level as any implement will.
/ Moldboard plows
Here is a Ferguson plow service manual: http://ploughmyfield.com/files/Plough Service Manual.pdf
Your Ferguson plow should fit every Category 1 Three Point Hitch and turn dirt beautifully.
I am sorry you are struggling.
The Ferguson manual is exactly what I need. IMG_0163.JPGIMG_0165.JPGIMG_0163.JPG. It seems that my problem stems from damage suffered by the plow many years ago. The beam was broken in the curve, but appears to have been well-repaired with long 1/2" fish plates welded to both sides. For all rocks I have hit, there is no sign of stress or failure. The serious problem appears to be the share. From the point to the wing tip is 18 1/2", and the rough wingtip indicates modification with an acetylene torch. The landside is 17" long (not including the point). The distance from the landside to the wingtip is 10 1/2", and should be 16". To achieve the 16" it appears that the share should ~28" long. Does that sound right? I searched the internet for Ferguson plow parts and came up with nada. Any suggestions?
/ Moldboard plows #11
Your plow and two other Fergusons.
Bruce
/ Moldboard plows #12
They did make an economy short share. Along with that, the moldboard was longer, narrower, and had more roll to it. If I remember right, it was designed to plow sod, and turn it over well to cover. Back in a time, when farming was more diversified. Fields would be sown for grass for hay, then 4, or so years later, after alfalfa, or clover reached it's peak, it was then turned over to pasture. Somewhere within the crop rotation, sod was plowed under,and a commodity crop was planted starting the cycle allover again.
If you can't adjust the plow's drawbar far enough over to align the wing tip of the share, with the inside of the left rear tire, then it is going to kick sideways, doing what it is doing now.
You may be able to replace the share, and get what you need. But, you may need to replace the moldboard, and possibly the landside also. That being said, oem parts are nearly non-existant, but there is hope. There is a fellow here in Ohio that makes new "Blacksmith" shares. Last year (I think) I guided a fellow in Washinton State to him, who had an IH Fast Hitch Plow Chief plow, and had exhausted all efforts to find new parts, and was afraid he'd have to find another tractor to plow his acreage he grow produce commercially. I sent him the link to Ploworx, and within a week, he was back to plowing. The fix wasn't cheap, but a lot cheaper than replacing his tractor and all.
I'd suggest if you want to,follow this link Ploworx Plow Parts , contact Steve with what you have, and see what he can do for you. If you're a fan of FaceBook, he also has a FB page, and numerous photos'/video's of many satisfied customers. Some, as far away as in the Netherlands. Here is a link to his FB page Ploworx - Posts | Facebook
Otherwise, it may be an idea to look for another plow. Up to you.
/ Moldboard plows
I don't plow often enough to justify any serious investment. I plow and harrow after digging up Christmas tree stumps. This smooths the ground and distributes 8-10 yrs of fertilization applied in bands. For serious deep incursion into the hardpan I used my newly- fabbed subsoiler today. It would have sucked the draft links right to the
ground ! With this new knowledge, I think my plan will be to subsoil for deep impact, followed by a 10" Brinley plow behind my Ford 1210. Jeff's plow manual gave me all the critical dimensions needed for me to make an educated decision.
/ Moldboard plows #14
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
BUNDLE OF APRROX (45) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
2013 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A61568)
2013 International...
2006 Ford F-650 24ft. Flatbed Truck (A61568)
2006 Ford F-650...
UNUSED FUTURE D39-39" HYD TRENCHER (A62130)
UNUSED FUTURE...
