rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,968
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Ah, yes.... the famous Yanmar clank and knock.... BTW, congrats on your purchase. You've just inherited a mechanical icon.
Those old two cylinder Yanmars were a sleeve-block engine with a steel cylinder shrunk into an iron block. That's a pretty good way to build a bell, and part of the reason for the nickname, "YammerHammers".
The noise doesn't seem to affect their reliability. Yanmar also made a series of single cylinder marine diesels & "long tails" that were even louder. They sounded like someone driving a fence post into the ground with a sledgehammer.
Oddly enough, they also made three cylinder & 4 cylinder engines at that time that were remarkably quiet and balanced. Especially the three, some of which featured an indirect injection head geometry which further quieted them down.
Many of the two cylinder tractors were thermosiphon cooling rather than having a water pump. Is yours? If you look at the front of the engine, what looks like a water pump is actually the generator - well, technically it's a magneto type alternator... but the point is that the cooling is dependent on physics rather than a pump. It works well enough, but is just different enough to be worth knowing about.
rScotty
rScotty
