Cheap, sturdy, handy chainsaw holders.
/ Cheap, sturdy, handy chainsaw holders. #1
MechanicalGuy
Beautiful South
Kubota mx5200
So I've seen no shortage of high dollar expensive chainsaw scabbards. Here is my solution. I use my bike rack that fits into a 2" receiver, which also doubles as my weed wacker holder when I'm driving around or in my tractor, and I bolt on a piece of pressure treated lumber that I've made a bore cut into with whatever chainsaw I will be carrying. These two are affixed to my rack and they hold my ms441 and my little husky simultaneously. I paint the lumber black so as to look better, and this is a solution that can be bolted onto four wheelers cars trucks etc. The lumber is really cheap in comparison to scabbards, and I make the bore cuts safely by clamping the wood in a vertical position onto something sturdy so I can plunge into the lumber and keep the cut aligned.
/ Cheap, sturdy, handy chainsaw holders. #3
That looks cool! Got any pics of it attached to the tractor?
Thanks,
/ Cheap, sturdy, handy chainsaw holders. #4
If I use chainsaw, I need the grapple, then I need the ballast box. I made a wooden box to store chainsaw in the ballast box. Odds of accidently running over it greatly diminished. Quite an exciting ride when saw falls out of bucket and front wheel "finds" it.
I put the 2" receiver in my ballast weight.
/ Cheap, sturdy, handy chainsaw holders. #7
I recently built a removable chainsaw scabbard and tool holder that mounts on the inside of tractor FEL tower. Some pics are attached.
I had wanted to add a chainsaw scabbard to my tractor for long time, but my chain boxes took the most convenient spots for one. So I came up with another way that is working out really well.
If you're interested, I cover the dimensions and build details in a video.
This design should be fairly easy to adapt to other loader designs. Anyone with some angle iron and a welder handy should be able to make a version of it for their tractor.
/ Cheap, sturdy, handy chainsaw holders. #9
Cheap scrap pile tool, chain, chainsaw, gas/oil holder. Additional skid plates help protect tractor hydraulics too. Took time and effort up front but saves so much time and much safer now.
/ Cheap, sturdy, handy chainsaw holders. #10
Here's my version. Note that there is a tool roll and bar oil in the loader mount & held there by the chainsaw blade.
The most useful things I've put on the tractor are probably the 4wd lockout (made from a gate lock) and the little plastic MAIL toolbox on the backside of the backhoe control box. That Mail box was $1.00 at the doller general store. That would be a nice place to mount a nicer box, but that one works surprisingly well, sturdy, & stays dry.
rScotty
/ Cheap, sturdy, handy chainsaw holders. #12
Here is my version of a homemade chainsaw scabbard, one for each side, I like to have an extra saw with me. The saws are both Husqvarna 61.
/ Cheap, sturdy, handy chainsaw holders. #13
Here's my cheapos and fun to build.
/ Cheap, sturdy, handy chainsaw holders. #14
All great add ons. Now I have me thinking 🤔
/ Cheap, sturdy, handy chainsaw holders. #16
... I bolt on a piece of pressure treated lumber that I've made a bore cut into with whatever chainsaw I will be carrying. These two are affixed to my rack and they hold my ms441 and my little husky simultaneously. I paint the lumber black so as to look better, and this is a solution that can be bolted onto four wheelers cars trucks etc. The lumber is really cheap in comparison to scabbards, and I make the bore cuts safely by clamping the wood in a vertical position onto something sturdy so I can plunge into the lumber and keep the cut aligned.
I did the same for my first holder. I bore cut into plain 2x6. I did not use pressure treated, since most of that stuff is corrosive. (Though I suppose the chainsaw is not in there long enough to be a real issue.) It lasted for a couple of years before the board split. clamping it to one of the bars on my brush hog probably did not help it's longevity.
I think my next holster will be made out of some used plastic cutting boards: I'll cut two holster shaped side, and use smaller pieces as spacers along the edge. Just waiting for garage sale season to start up, so I can pick up the cutting boards cheaply.
I'm still debating about the best place to mount it. Hnging it off the outside of the FEL upright concerns me, since I often work in tight quarters in the woods and on uneven terrain. I'm afraid it will only be a matter of time until I smash my saw against something.
I will probably put something on my logging winch, but I still need a place for when the winch is not on the tractor.
/ Cheap, sturdy, handy chainsaw holders. #17
I built a few custom parts for some of my RC rock crawlers with cutting board material. I ripped them in a table saw, and laminated them together to make blocks that I shaped with drills and dremel using JB Weld. So just fyi, JB weld layers together and clamp them tight works really well!
/ Cheap, sturdy, handy chainsaw holders. #18
It took $3.00 in bolts to make this and used plywood.
I need it to last 3 months and I have more scrap wood. This was an awesome idea.
/ Cheap, sturdy, handy chainsaw holders. #19
Good idea using the bike receiver rack that goes into your ballast barrel MechanicalGuy. Should work good and saves some work.
I make scabbards from scraps of 1/2" CDX plywood. Put on as many coats as it will soak up of 50/50 boiled linseed oil and turpentine. Won't rod, split, or soak up water.
EDIT: Duh... Just noticed I'm about 3 months late
gg
/ Cheap, sturdy, handy chainsaw holders. #20
I welded a piece of 4 inch pipe to the side of the loader frame works for me
I welded a piece of 4 inch pipe to the loader frame
Bobcat T66 Compact Track Loader (A64047)
Bobcat T66 Compact...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
Trava Long Gooseneck Livestock Trailer (A64047)
Trava Long...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
