Pallet Forks ... yet another home made set.
/ Pallet Forks ... yet another home made set. #21
Those really turned out nice. I could not live without mine.
Great job on the forks.
/ Pallet Forks ... yet another home made set. #23
Very nice - good idea with the stake pockets for a back rest :thumbsup:
gg
/ Pallet Forks ... yet another home made set. #24
I used the mast and forks from an old forklift... the mast has a cylinder that takes it up about twenty feet from the ground, and the forklift arms are fairly sort at five feet, but manually adjust sideways .. It's on an old tractor with a Minneapolis loader, with a newer quick tach ... The quick tach has bent pins at the top, and pieces of one inch plate at the bottom for the locking pins to go into ..The quick tach forklift itself weighs maybe 1000 pounds,[goes on in place of the bucket], and I haven't tried picking anything up more than 2500 pounds or so, the loader lift arms squeal out then .. The mast with arms only cost me fifty dollars at the local scrap dealer
/ Pallet Forks ... yet another home made set. #25
You have a picture of your forks or description?
Here are mine. :thumbsup:
/ Pallet Forks ... yet another home made set. #26
Wow someone else with tapered down forks, welcome to the Tapered Down Fork Club, so far it's a small club of you and me. Are these some you made or bought, does the square tube in between stop side to side movement?
Looks like a nice 50s Farmall with add-on FEL post model and year so I can youtube it, then you stiffeners on the cutting, never seen that before must be you have lot of lift power, I could go on about the barn build and fantastic scenery but you heard it before.
/ Pallet Forks ... yet another home made set. #27
I bought them from Here thought about building some for a long time and sure could of, didn't really have time so I forked up (ha) the money for those.
My Farmall is a 1944 M - she's been sulking some since I bought the diesel Agco that sits inside now, she's a tough old bird and has to stay outside. :)
/ Pallet Forks ... yet another home made set. #28
How many of you have forks for the 3pt lift? There is a lot more capacity back there if you just need to move things without going too high. I built mine from parts off an old forklift, and even use the 48" forks.
David from jax
/ Pallet Forks ... yet another home made set. #29
I have to go high.
/ Pallet Forks ... yet another home made set. #30
I just love them ole tractors with the ole tractor sound, it was tough but did find a couple tractors like yours, seems like wide front ends are a rare breed back then. You still on the 6 volt system and points? If I had that tractor, I'd half-track it. Super M Farmall Tractor w/Wide Front End! Online Auction Only! - YouTube
My Tractor's Not What I Thought it Was! - YouTube
/ Pallet Forks ... yet another home made set. #31
I cant get a ton of pressure on my tractor forks, somewhere around 700 lbs. A quick switch bucket is on my bucket list though, clamp on forks are the only quick fix option for a pin bucket.
My father built the forks for my 275 but I ended up welding angle iron onto them, drilling 1/2 inch holes in the bottom and sides of each side of my bucket, and bolting them in place. It worked really well and I didn't even bother to take them off for light plowing. When I bought this tractor I didn't want to drill holes, so ended up with a set of el cheapo Titans. In hindsight I wish that I'd bought a bolt on tooth bar and built a set of forks using those same holes. The Titans are ok for what they are made for, but they aren't made for how I was using them.
My father also made a set of rear forks for the 8N which we used when I was growing up; we used them to carry pallets laden with boxes ready for planting seedlings. Once he got a tractor with a bucket he quickly realized that it was easier to get a scoopful if potting soil, and fill the boxes as needed.
/ Pallet Forks ... yet another home made set. #32
Thanks - It's a 12 volt with points, the guy before me installed a hillbilly power steering unit and it works like a dream!
Mine is not a super M though, and no live hydraulics which can really be a pain at times, plus the FEL runs off a rear PTO pump so if the clutch is in there is no FEL hydraulics. :mad:
Done a lot of stuff with the ol girl. She has a flat spot on the flywheel, and if it stops just right I have to put a wrench on the front and give her a little crank to get on the "good" flywheel teeth. (Dang, done it a thousand times now) LOL.
Great for Hay Rides too. :thumbsup:
/ Pallet Forks ... yet another home made set. #33
Do you have picture somewhere with your forks on with binder?
Sorry I missed your post. I don't have a picture handy but my forks are similar to yours. At the rear of the fork is where the chain is connected. In front of the part that slide over the bucket is a round hole (the ones I see now have a hole that looks like it's made to slide chain into (round with a loop on the top)). One hook of the binder goes into the hole while the other hooks on to the chain that's wrapped around the back of the bucket. This is the best picture I could find on the net. I use lever type binders but I have Dixie binders that can be locked when cinched.
/ Pallet Forks ... yet another home made set. #34
I was thinking lever binders, those ratchet ones are best for this use. Does that stabilizer bar in between help to keep forks straight?
/ Pallet Forks ... yet another home made set. #35
It's really not that difficult to build a set of fixed width forks for a pin on loader. Maybe it's just cause I'm used to getting the most out of a loader but if I had a set of clamp on bucket forks I'd be looking to convert them straight away.
/ Pallet Forks ... yet another home made set. #36
Tool I use to tighten the bucket pallet forks. The short thick wall tubing top of the hammer head fits the bar handle top of the clamping bolt. Rotates to always have a good angle on the tightening bolt. The extra leverage secures them better. Have the option to chain them down too but have never needed to.
/ Pallet Forks ... yet another home made set. #37
Neat Swiss Army Farmer Tool. A tad big for the pocket, but one should have room somewhere on the tractor.
/ Pallet Forks ... yet another home made set. #38
Love that thing Smokeydog. I have a small collection of multitools like that. They are always a bit compromised in function, but they can get the job done in a pinch. I carry a different one in each of my tractors, side-by-sides, etc; trying to figure out which works best and where. I would like to find or make the ultimate 3-point hitch tool.
CATERPILLAR DP40 STRAIGHT MAST FORKLIFT (A64279)
CATERPILLAR DP40...
Caterpillar 920/930 Wheel Loader Service, Parts and Maintenance Manuals (A63117)
Caterpillar...
KUBOTA RTV 900 UTV (A64280)
KUBOTA RTV 900 UTV...
2020 Freightliner M2 106 Altec LR7-56 56ft Forestry Bucket Truck (A61573)
2020 Freightliner...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
