Pallet Forks ... yet another home made set.
   / Pallet Forks ... yet another home made set. #21
Those really turned out nice. I could not live without mine.
Great job on the forks.
   / Pallet Forks ... yet another home made set. #22
   / Pallet Forks ... yet another home made set. #23
Very nice - good idea with the stake pockets for a back rest :thumbsup:
gg
   / Pallet Forks ... yet another home made set. #24
I used the mast and forks from an old forklift... the mast has a cylinder that takes it up about twenty feet from the ground, and the forklift arms are fairly sort at five feet, but manually adjust sideways .. It's on an old tractor with a Minneapolis loader, with a newer quick tach ... The quick tach has bent pins at the top, and pieces of one inch plate at the bottom for the locking pins to go into ..The quick tach forklift itself weighs maybe 1000 pounds,[goes on in place of the bucket], and I haven't tried picking anything up more than 2500 pounds or so, the loader lift arms squeal out then .. The mast with arms only cost me fifty dollars at the local scrap dealer
   / Pallet Forks ... yet another home made set. #25
You have a picture of your forks or description?
Here are mine. :thumbsup:
   / Pallet Forks ... yet another home made set. #26
Wow someone else with tapered down forks, welcome to the Tapered Down Fork Club, so far it's a small club of you and me. Are these some you made or bought, does the square tube in between stop side to side movement?
Looks like a nice 50s Farmall with add-on FEL post model and year so I can youtube it, then you stiffeners on the cutting, never seen that before must be you have lot of lift power, I could go on about the barn build and fantastic scenery but you heard it before.
   / Pallet Forks ... yet another home made set. #27
I bought them from Here thought about building some for a long time and sure could of, didn't really have time so I forked up (ha) the money for those.
My Farmall is a 1944 M - she's been sulking some since I bought the diesel Agco that sits inside now, she's a tough old bird and has to stay outside. :)
   / Pallet Forks ... yet another home made set. #28
How many of you have forks for the 3pt lift? There is a lot more capacity back there if you just need to move things without going too high. I built mine from parts off an old forklift, and even use the 48" forks.
David from jax
   / Pallet Forks ... yet another home made set. #29
I have to go high.
   / Pallet Forks ... yet another home made set. #30
I just love them ole tractors with the ole tractor sound, it was tough but did find a couple tractors like yours, seems like wide front ends are a rare breed back then. You still on the 6 volt system and points? If I had that tractor, I'd half-track it. Super M Farmall Tractor w/Wide Front End! Online Auction Only! - YouTube
My Tractor's Not What I Thought it Was! - YouTube
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
2006 APPA TL (A55788)
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
