F series question
/ F series question #1
om21braz
Lexington, NC
Does anyone know what F series began having a deck that will pivot up 90 degrees for clean-out? FXX60, 80 or not until new 90?
Sorry, but I researched thru a fair amount of previous threads without finding an answer.
/ F series question
That is more than I did know - Thank You! Been looking for a while and saw a video showing a new F2690 and how the deck pivots up. I think that is must have feature. My present ZD has the pivoting axle & jack, but you still have to get under it to clean the deck out.
/ F series question #4
I have the f2690 and it has the deck that lifts. I ordered mine with the 72 inch deck, and for me it is a bear to pick up to service. Mine has the mulching kit on it so grass does accumulate, so of course that makes it heavier. It could also be as you get older those types of chores get harder.
/ F series question #5
You had better believe it
/ F series question #6
/ F series question #7
Do the new ones swivel up without having to disconnect the drive shaft?
I don't disconnect my driveshaft , just position so the opening in the u
joint is in the bend as you rotate it up.
/ F series question #8
the first ones were the FZ2100 & FZ2400 zero turn F series mowers from back in 1992, I was lucky enough to be present when they brought the prototype to our dealership to show.
Was never offered again until the newer models of today
/ F series question #9
F3060 was sold from 1996 - 2005 and the deck lifts up hydraulically & swivels 90 degrees relatively easy for service. No need to disconnect the driveshaft.
It's a 72 inch rear discharge deck.
I have not had to deal with much built up grass underneath so far, but if that ever becomes a problem I will rig up a small chainfall to assist swiveling the deck.
View attachment Kubota - Prior Prorducts F3060 Specs 1996 -2005.pdf
/ F series question #10
Here is what it looks like.
It is true, with a 72 inch deck the front drive wheels of F3060 have to be 2 - 3 inches elevated, in order to lift the rear anti-scalp wheels off the ground so you can swivel the deck all the way & lock it in place.
:silly: Not a big deal once you figure it out.
/ F series question #11
Kind of think that's an old design. My F3680 72" deck the rear deck anti scalp wheels are on a bracket that you release and they swivel out of the way.
/ F series question #12
Yes it's also missing the Diesel particle filter all the new ones have!
Funny eh?
/ F series question #14
I don't unhook the driveshaft but it's a good idea to make sure the grease fitting on the shaft isn't top dead center, or you risk bending the shaft guard when you tilt the deck up. I learned the hard way. Now I just rotate the shaft by hand if needed prior to tilting the deck up.
/ F series question #15
My F3680 has none of that stuff.....wouldn't have it if it did.
How do you like the 3680? I found a nice one with 150 hrs on it. He wants a good bit for it...
/ F series question #16
I like it a lot. My previous mower was a zd326 and I kept getting it stuck Time After Time. I also have some slope areas Pond dams and the like and although the zd326 could navigate it would tend to crab walk it and would leave a track on the dams because this machine was constantly slipping a little bit. The F3680 solved that. It will mow faster than you are capable of handling machine it is fast.
/ F series question #17
Nice! Been pretty reliable? Is it more comfortable to operate than the 326 ( which is also what I have)? Is yours a rear discharge? If so, how do you like it?
/ F series question #18
I bought this mower used with very little hours. I simply bought what became available I would have taken side discharge or rear discharge and what became available was a side discharge. I think the rear discharge would be nice if you've got a lot of trimming to do around houses and stuff like that but I think if you get into a heavy grass you're going to have trouble getting the volume of grass out from under that deck with a rear discharge. Heavy grass will result in a large volume of grass that's getting thrown out from that mower.
If the wind is blowing wrong this mower will cover you in grass because 72 in cut is a lot of grass. I also never even use the mower with the large flap to cover the side opening up because of trimming reasons I'd be hitting that thing every time you turn around. So what I did is added a flap like the grass flap controlled by an electrical actuator. It works well except it will wind row a little bit when the flap is closed.
Only issue that I've had is my own fault in not greasing the machine right. There is a short pretty well hidden shaft between the moter and the hst area below the radiator. You have to put your head literally under the machine and look up. It's easy to miss and I failed to grease is it properly. Came apart, busted nipple on radiator. It was a real bear to fix but did managed to get it fixed myself without taking it to the dealer.
I'd definitely buy the mower again.
/ F series question #19
Great input. I appreciate your time!
/ F series question #20
Wow, you were in the same predicament I am in now. I mow real steep ground with a ZD331. It’s a beast and does the job, but it leaves me wishing for 4WD.
I’ll never forget the day I was at the dealer a few years back. He had a used F3680 and a used ZD331 siting for sale side by side. I tested both and felt safer on the ZD because of lower center of gravity. I had no idea at the time the F3680 would have been a better choice (you can still hear the sound of me kicking myself for not buying)
I should have bought both. Each one was in great shape, about 1500 hours on both and $8500 for each one.
I could have tested both out and sold one of them later. :(
