Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,621
Can you take pictures from the other end? I think that can be swapped to 3 point. I may be wrong, but why not look at it.. Looks like the mount can be flipped, the round tubes front and back both have ears in what looks like the same location. If the gearbox can be flipped also.
Just looking at if it is possible.
/ Let's talk flail mowers #6,622
I can only post one picture at a time, not sure why. Thanks for the suggestion. I had the same idea. I tried taking the hitch arms off and flipping and rotating the gear box. I couldn't make it line up without a bunch of cutting and welding, something I'm not able to do.
Has anybody ever heard of kverneland flail? There is one going up on auction near me. If so, are there dealers and parts available? Thanks so much.
/ Let's talk flail mowers #6,623
Measure the spacing between the ears on both front and rear tubes. If they are the same, then measure from front and rear tubes, to the drive tube coming out of the gearbox side. If they are the same, then I bet it can be reversed. The gearbox mounts to the upright where the toplink connects. And I bet the bolt pattern is symmetrical. Yes you will be wrenching, but you won't be cutting and welding. Where are you located? I could help if you're close.
/ Let's talk flail mowers #6,624
Kverneland has been building and selling farm equipment for years and they have a dealer network here in the United States.
go to the auction and look at it before you buy as you have ot be more concerned about whether you have enough power to run it.
Spending the money on the parts from Messicks to convert it or buy the hitch parts will still get you a flail mower that will outlast your current mule.
/ Let's talk flail mowers #6,625
Since it is a front mount low production unit, it has value as is. Just advertise several places, somebody out there needs it.
I know from experience that out front mowers are so much better and easier to use than rear 3 point or pull behind mowers.
/ Let's talk flail mowers #6,626
I've heard the name in relation to farming & hay equipment. Might be a crop flail. Thise are really wide & optimized for chopping up corn stalks & what not. The crop flails I've seen are way to bug for a CUT & not built for mowing out of a relatively smooth field.
/ Let's talk flail mowers #6,627
I took the hitch arms off, unbolted the gearbox and flipped its direction on the driveshaft. The gearbox drive shaft isn't centered front to back. I was unable to get the hitch arms under or over the drive shaft. After speaking with alamo, their tech guy said that it would spin in the wrong direction anyway, due to the pulley and belt setup.
I'm kind of afraid to make all the parts purchases and it still have it not work correctly.
After some searching, did I read this correctly? Kubota bought kverneland?
/ Let's talk flail mowers #6,628
I wouldnt wory much about HP. I ran a 7' behind a 25pto HP L3200. You can compensate by going slow (especially with a HST).
I would heavily wory about your weight & width. Your TBL will be heavy for its class, but very narrow for a 4,000 CUT.
My L4060 feels it when I shift my Super Bull (1,700lbs 8'). When i offset it fully to the right the belt guard is even with the left tire. So despite being heavier it's likely putting less side torque on my 5,000lbs 72" track machine than that smaller mower would when it hangs way out. The heavy end of the mower & the gearbox stays on the left of or equal to the drawbar giving me some balance still.
I'm gonna guess that you could pull it off ok if the roller on the mower stayed supported by the ground. But if it came off the ground it might get pretty hairy quickly.View attachment 598521
Quick update to this conversation. Everything Fallon mentions is pertinent. I decided to add wheels to the mower to make it safe to operate with the narrow B21 and also put much less stress on the three point assembly.
/ Let's talk flail mowers #6,629
Anyone for a rousing game of "name that flail?
This one has come up for sale near me for what I consider a decent price. 48" in width, so a nice size for the little yanmar.
I think its a Ford 917 of some flavor but some parts look significantly different than what I remember from the one I had previously. The lift pin attachment also seems to be missing the float arms I remember? Could that be factor or is that a hack job somebody did?
/ Let's talk flail mowers #6,630
Downsizing -- is it your intent to lower those extra wheels taking weight off the roller , both for transport and to keep control and prevent sideways tipping when the cutter is swung out I suppose ? Nice installation/mod. How is that mower working out reaching out over bank edges, ditches, etc. ?
/ Let's talk flail mowers #6,631
The belt guard certainly looks like a Ford.
/ Let's talk flail mowers #6,632
I have a 60" mower that looks like that. It's painted Ford blue and says "Ford 917 Special" on the belt shield.
/ Let's talk flail mowers #6,634
I'm going to say that it is a Ford 917 that someone hacked off the original float arms and welded on solid plates. I had a 5' 917 and it was a good mower - had to sell it when I got a bigger tractor. You can put Alamo/Mott blades on them, but that's the only part that is interchangeable. Messicks should have most of the parts you'd need for the mower otherwise, including the original (course cut) airplane wing blades.
/ Let's talk flail mowers #6,635
The wheels are for moving the mower from place to place and positioning for mowing. Once in position, the wheels are lifted so the mower rests on the roller. They operate very smoothly when the mower is pushed out to the side and back again, also driving around the yard. So far I only operated it in the yard to make sure everything works as planned and to fit the PTO driveshaft. I have a few steep banks to mow, but what I mostly have is a lot of uneven ground and difficult to reach areas under the redwood trees. I wanted the tilt cylinder (used in float) so the mower can tip from side to side and better track the ground. I wanted the side extension so I could get under and around the trees.
/ Let's talk flail mowers #6,636
Yeah I had a 917L at one point when I was first clearing my property. Would chew up and spit out anything. I could put float arms back on it but really don't need them. Plan to use it for what little heavy stuff I have around the fence rows.
/ Let's talk flail mowers #6,637
That was kind of my guess. Was going to match the float arms to mine as other bits look pretty close to my 917.
/ Let's talk flail mowers #6,638
Not sure if already discussed here, offset flail on a subcompact:
/ Let's talk flail mowers #6,639
Just received and set up my Woodmaxx FM78H mower this week. Went pretty smooth.....with it taking me about 3 hours to get things set-up properly (yeah....I'm a bit slow). The pics below show the offset.....which, at the time of the pics, I had not adjusted for level. With a little fine tuning.......I took it for a spin. Seems like I have plenty of power for this unit....tho there is not much heavy stuff to cut yet. Really allot of bang for the buck with this unit. Seems ****-bent-for stout and property engineered. I bought the flail blades (all they had) and an extra set as well as spare belts. For my needs I think the knives will do a nicer job. I was quite impressed with the build quality and materials received. The assembly manual has some variations from current production....but nothing that cannot be figured out. Looking forward to mowing season. Gonna love that hydraulic shift right. OH....and the paint makes a good match for my Bota. flail centered.jpgFlail shift right.jpg
/ Let's talk flail mowers #6,640
Had a quick look at their website and the products look pretty good!
I found a statement that the chipper knives are US made but nothing about the rest of the equipment or flail mowers origin - anyone here with more info on that?
Steiner TL348 50in Rotary Tiller Tractor Attachment (A64553)
Steiner TL348 50in...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
ROBINAIR MODEL 34788NI AC RECOVERY UNIT (A67714)
ROBINAIR MODEL...
WeeDoo (A66738)
WeeDoo (A66738)
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
