30hp Chinese Bulldozer Parts
   / 30hp Chinese Bulldozer Parts #91
Ok so i have pulled it down a little more, I should have said something about the oil everywhere, thank you for pointing it out for some who may not realize it is meant to be dry. I was wondering how the steering while pushing can cause the warn groves in the clutch/brake drum. I thought that the cause would more likely be a bearing failure tho i have not found any bearing faults yet, they seem OK. I can see how it would cause things like the axle twist off that looks nasty. So far all i have found is about 3/4 inch of an o-ring in the washer on the clutch to final drive shaft missing (would explain all the oil where it is not meant to be) i suspect the people at Midway damaged it when they put new brake bands in it under warranty.
   / 30hp Chinese Bulldozer Parts #92
Hi Mark Rawlins here, I have a 1995 JLW-D2 that I need to repair
and I made the mistake of lending it to a friend, who had a problem with it and took it apart, and I finally got all the pieces back -- and a year later I finally got it rebuilt and running -- Sort of
MY PROBLEM, the left steering clutch will not disengage, when I started the dozer and checked the Oil it was completely dry, so I assume the clutch assembly has basically "siezed up" I have the owners manual that show all the parts,
MY QUESTION, does anyone know how I get to the clutch assembly to take it apart? I assume I have to take off the track and the drive sprocket? Is that right?
   / 30hp Chinese Bulldozer Parts #93
Hi Mark, welcome. You should start a new thread. I'll be glad to help you all I can.
   / 30hp Chinese Bulldozer Parts #94
Sir I’m sorry for troubling you but I have a NorTrac 35XTD dozer with steering troubles, but I seen you had a post on how to redo this problem would you be grace enough to share it with me thank you Clyde
   / 30hp Chinese Bulldozer Parts #95
It could be a Guilin then. Is it a two or three cylinder engine?
If it's a three cylinder, then you better snap up that clutch set that Chip has on eBay. You aren't going to find these at NAPA!:D
Hi Bob. I have a DH326ST dozer that looses power/forward motion after about 30min of use. Trying to figure out if there is an issue with the forward/reverse valve or the shuttle clutch. Any assistance you can lend with parts, manuals or advice would be greatly appreciated!
   / 30hp Chinese Bulldozer Parts #96
Welcome, Mattbud.
First of all, I have no parts. All I have is Al Lamore's shuttle clutch guide, and the factory dozer and engine owner's manuals. There is no service manual available, the owner is presumed to possess appropriate skills and knowledge.
Several things can contribute to the symptom you described. Does your machine slow in forward motion while maintaining engine speed (no load, blade up), or does engine speed slow while maintaining a set throttle position? What is the engine temperature when the symptom occurs?
   / 30hp Chinese Bulldozer Parts #99
Tytan Tractors up in Washington may be able to get you parts and support for those Chinese Dozers.
When I was up there 6 months ago, they were parting out 1 or 2 of the dozers, but presumably could get some new parts too.
   / 30hp Chinese Bulldozer Parts #100
Wow! You didn't have to take it down that far just for steering clutches and brake bands. Yes, all the friction material has become saturated for sure. Not worth the time to try and clean it, because you can't. The new clutch discs you get will probably be a bonded sintered bronze composite which can be cleaned. Also check the clutch plates for wear and warpage, these can be reused if they qualify. Circle-G Tractors, Keno Tractor, and Northern Tool are just a few of the dealers that stock parts.
hi bob.. how do you get to the clutch and brake bands without open heart surgery
25ft Tag Trailer (A56436)
25ft Tag Trailer...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56436)
Midwestern...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
