Just had a well put in. Thoughts appreciated
/ Just had a well put in. Thoughts appreciated #31
As I understand this and recall from previous threads:
  • This is unimproved, unoccupied property.
  • There are no buildings or utilities.
  • You're not there much of the time.
  • You use a generator for power only as needed.
  • For now, you only want water to fill the totes/tanks to be used for irrigation, meaning you'll only be running the pump intermittently and do not need constant pressure.
If that's all correct, I see no need for a tank/bladder to be installed. Use the generator to power the pump as long as needed to fill the tank, then kill power to the pump. The only issue may be priming the pump each time. If you install a hydrant, you'll need to leave the valve open any time the pump is running.
You might want to buy/install or build a small portable/temporary shed that should cost $500 or less.
Your recollection is correct, the only thing Im unclear of at this point is whether I should install a foot valve AKA one way valve within the line so that the water does not completely drain back into the well when I unplug the generator?
/ Just had a well put in. Thoughts appreciated #33
Will you be using a in well pump or a pump above-ground? A in-well pump should have one built in, an above-ground pump will need one.
Aaron Z
Aaron Z
In ground. I thought I had seen u tubers installing valves with in ground systems? I guess I was mistaken or not same scenario. Thanks
I think at this point I'm gonna ask well driller how much more I owe him for the work done thus far and just finish the work myself.
Don't know if thats feasible.
/ Just had a well put in. Thoughts appreciated #36
Aaron Z
For my in-ground pump, the well driller installed a check valve since the pump didn't have one. So check with whoever installs the pump to see if it already has one. The in-ground pump should be sitting in the water so priming it should not be needed. Since you are in Florida, you shouldn't have to worry about freezing of the water in the pipes so I'd use a check valve.
Another thing to check is if there is a minimum "on" time the pump needs to run to cool the pump. Mine is 2 minutes.
Thanks everyone for the tips/advice.
At this point I have to see what I am obligated toward I guess. I know the well company pulled permits ( or at least Im assuming since its all part of their package deal ) Maybe its a fact that they need to do things a certain way to appease the county if ever there was an inspection.
If that is the case than Ill deal with doing things the way that I want them done after alls said and done and just eat the extra expense. I may have no choice
/ Just had a well put in. Thoughts appreciated #38
If they have an underground pump, they would most likely be installing a check valve after the pump rather than a foot valve (a check valve only allows water to go one way, a foot valve has a check valve as well as a screen to keep crud out of the valve).
Aaron Z
I did not know there was a difference. Ill try and remember that. Thanks
/ Just had a well put in. Thoughts appreciated #40
It’s pretty simple. Galv wells get the pump hung on galv, pvc wells get the pump hung on pvc or plastic. The reason is that a 4” pump is really 3.9” and it’s a tight fit in a 4” well. In the future when that needs to come out you may need rigid pipe so you can free the pump from the scale and rust build up.
We don’t use galv pipe for wells here anymore.
Iranch IRGC40 (A60463)
2014 International Derrick Digger Truck (A55973)
2014 International...
30ft Highway Trailer Co. Lowboy (A61307)
30ft Highway...
CFG Industrial MX12RX (A60463)
CFG Industrial...
Rooster Weathervane (A55853)
Rooster...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
