Bolt on cutting edge and bolt on hooks
   / Bolt on cutting edge and bolt on hooks #11
Used them for the first time today. Picked up my pallet forks from the freight terminal and what a perfect way to unload them from my truck.
Not trying to nit pick here. Just thought I'd point something out.
After your cutting edge gets a little worn, it will develop a sharp kinda serrated edge. The tractor and load rocking side to side will create a sawing action and cut your ropes in about five seconds.
Using chain instead pretty much solves this problem.
Good move installing the hooks. I can't imagine having a bucket without them.
I've also welded a set of hooks at a 45 deg angle near the top of my fork frame. They come in handy if I need to drag a pallet back so I can get under it. They're also good for securing loads on the forks.
I no longer have these forks, but they have the hooks welded in the same general area as my present set.
Good lookin out. :thumbsup: I had the bucket rolled enough to keep the cutting edge away from the rope. Ive got chains.
I like that setup you have with the welded hooks on the pallet forks. Gonna look into doing that. Thanks.
   / Bolt on cutting edge and bolt on hooks #13
My version: I added D-rings to the sides and top of my Land Pride forks so I could more easily tie my deer shooting houses to my tractor forks when moving them and emplacing them.
   / Bolt on cutting edge and bolt on hooks #14
Me, not being a good welder , bought Ken's bolt on hooks. Been very happy with them.
I bought a Piranha tooth bar, which let's me break through the diabase (iron rock) in my soil which stopped me cold with the straight edge.
   / Bolt on cutting edge and bolt on hooks #15
I'm a big fan of weld on chain hooks. I even put one on my backhoe bucket.
I'm very fortunate, that my friend/neighbor has a Mig welder and a big shop I can use. He has really saved me from a bunch of work.
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2001 Ford F-350 4x4 10ft Flatbed Truck (A55852)
2001 Ford F-350...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
