Bolt on cutting edge and bolt on hooks
   / Bolt on cutting edge and bolt on hooks #11
Used them for the first time today. Picked up my pallet forks from the freight terminal and what a perfect way to unload them from my truck.
Not trying to nit pick here. Just thought I'd point something out.
After your cutting edge gets a little worn, it will develop a sharp kinda serrated edge. The tractor and load rocking side to side will create a sawing action and cut your ropes in about five seconds.
Using chain instead pretty much solves this problem.
Good move installing the hooks. I can't imagine having a bucket without them.
I've also welded a set of hooks at a 45 deg angle near the top of my fork frame. They come in handy if I need to drag a pallet back so I can get under it. They're also good for securing loads on the forks.
I no longer have these forks, but they have the hooks welded in the same general area as my present set.
Good lookin out. :thumbsup: I had the bucket rolled enough to keep the cutting edge away from the rope. Ive got chains.
I like that setup you have with the welded hooks on the pallet forks. Gonna look into doing that. Thanks.
   / Bolt on cutting edge and bolt on hooks #13
My version: I added D-rings to the sides and top of my Land Pride forks so I could more easily tie my deer shooting houses to my tractor forks when moving them and emplacing them.
   / Bolt on cutting edge and bolt on hooks #14
Me, not being a good welder , bought Ken's bolt on hooks. Been very happy with them.
I bought a Piranha tooth bar, which let's me break through the diabase (iron rock) in my soil which stopped me cold with the straight edge.
   / Bolt on cutting edge and bolt on hooks #15
I'm a big fan of weld on chain hooks. I even put one on my backhoe bucket.
I'm very fortunate, that my friend/neighbor has a Mig welder and a big shop I can use. He has really saved me from a bunch of work.
2005 Toyota Highlander SUV (A55853)
2005 Toyota...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2005 GMC C8500 Utility Flatbed Truck (A55852)
2005 GMC C8500...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
