Bolt on cutting edge and bolt on hooks
   / Bolt on cutting edge and bolt on hooks #1
scratchpad
Fresno
MF 2705E
Before i got balls deep into jarring up the bucket i figure i better put a cutting edge on to protect it. Loader came with a 12 bolt pattern that was very difficult to find the exact one for this loader for a reasonable price. Couldve had one made however convenience got the best of me on this one. Went to Massey and they ordered the correct one through agco.
Next up, ordered some "Kens bolt on hooks" as theyll come in handy.
   / Bolt on cutting edge and bolt on hooks #2
I configured my bolt on hooks from Ken the same as you have done. You will find them very useful.
   / Bolt on cutting edge and bolt on hooks #3
nice job
had you considered a bolt on tooth bar instead of the cutting edge, or is your application more scraping than excavation?
my tooth bar has made a world of difference digging compared to the straight factory fel bucket edge.
nice job
The loader came with holes in it for a bolt on edge so I figured I’d utilize it.
I might still be able to bolt on a tooth bar if I find that I need it. How is back dragging with it work for you. If I need more serious cutting in the dirt I’ll rent a skid steer or larger piece of equipment.
   / Bolt on cutting edge and bolt on hooks #5
back dragging is fine esp in float position (w/ only a slight bucket angle), or i'll use the bucket heel
good work. now time to get some mud on those surfaces :)
:thumbsup:
   / Bolt on cutting edge and bolt on hooks #7
Nice job!
   / Bolt on cutting edge and bolt on hooks #8
No idea what you will be digging but loaders even the big commercial ones are not designed to dig hard compact material. They really are made for loose material. Not saying you can not do it with a loader or fel. If you have a box blade with rippers on it try running them through before loading with fel. It may surprise people a fel frame can be bent. I know, been there and done that, not digging but lifting down tree. Do my digging with a blade or excavator.
For sure. Right tool for the job. Dug out 22+ trees this weekend.
Nice job!
Used them for the first time today. Picked up my pallet forks from the freight terminal and what a perfect way to unload them from my truck.
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2018 Freightliner M2 106 Lay Flat Roll Back Truck (A55852)
2018 Freightliner...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55314)
2022 John Deere...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
