Catagory 1-2 hydraulic top link
   / Catagory 1-2 hydraulic top link #1
longlane
Vineland, NJ
Ford 5000
Im looking for a hydraulic top link, Category 2 on the tractor end and category 1 on the implement end.
I have found manual top links in this configuration, but not hydraulic.
Any guidance would be appreciated.
thanks
   / Catagory 1-2 hydraulic top link #2
thanks
If you have the capabilities to weld it is really easy to change the rod end of a cylinder...otherwise is simple for a welding shop...
Another option is just use a fitted sleeve on a cat 2 HTL...
   / Catagory 1-2 hydraulic top link #3
   / Catagory 1-2 hydraulic top link #4
I also have his products and like them.
   / Catagory 1-2 hydraulic top link #5
   / Catagory 1-2 hydraulic top link #6
Pretty sure "not" was a mistake!?!? Funny that I do it all the time the other direction, I would leave out the word "not" from sentences. :confused3:
Bushing at Agrisupply:
Lift Arm Bushing Cat 1 To Cat 2 | Agri Supply 106048
Thanks for catching that..... :thumbsup:
YES.... It should have read:
"I CAN NOT RECOMMEND BRIAN OVER AT FIT-RITE HYDRAULICS HIGHLY ENOUGH".... It's what happens when my brain works faster than my fat fingers.... :confused2:
   / Catagory 1-2 hydraulic top link #7
For those that skim through posts, they might see "I can NOT recommend" and think OK, NOT this guy, and move on. I have a top link by Fit-Rite-Hydraulics. Good product, even came JD green.
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
Two Pairs of 8ft Fork Extensions (A55787)
Two Pairs of 8ft...
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
