Catagory 1-2 hydraulic top link
/ Catagory 1-2 hydraulic top link #1
longlane
Vineland, NJ
Ford 5000
Im looking for a hydraulic top link, Category 2 on the tractor end and category 1 on the implement end.
I have found manual top links in this configuration, but not hydraulic.
Any guidance would be appreciated.
thanks
/ Catagory 1-2 hydraulic top link #2
thanks
If you have the capabilities to weld it is really easy to change the rod end of a cylinder...otherwise is simple for a welding shop...
Another option is just use a fitted sleeve on a cat 2 HTL...
/ Catagory 1-2 hydraulic top link #3
/ Catagory 1-2 hydraulic top link #4
I also have his products and like them.
/ Catagory 1-2 hydraulic top link #5
/ Catagory 1-2 hydraulic top link #6
Pretty sure "not" was a mistake!?!? Funny that I do it all the time the other direction, I would leave out the word "not" from sentences. :confused3:
Bushing at Agrisupply:
Lift Arm Bushing Cat 1 To Cat 2 | Agri Supply 106048
Thanks for catching that..... :thumbsup:
YES.... It should have read:
"I CAN NOT RECOMMEND BRIAN OVER AT FIT-RITE HYDRAULICS HIGHLY ENOUGH".... It's what happens when my brain works faster than my fat fingers.... :confused2:
/ Catagory 1-2 hydraulic top link #7
For those that skim through posts, they might see "I can NOT recommend" and think OK, NOT this guy, and move on. I have a top link by Fit-Rite-Hydraulics. Good product, even came JD green.
