My LPGS
/ My LPGS #1
oosik
Epic Contributor
AMBER, WA
2009 Kubota M6040
Five years ago I bought a brand new Land Pride, land plane grading scraper( GS2584 ). I have a mile long gravel driveway that turns to concrete in the summer. The LPGS would just bounce down the driveway - doing a whole lot of nothing.
Well - today it was time to grade out a muddy, rutted, gouged 200 foot section of my driveway. It was dry on top but still had moisture in the gravel/dirt below. Previous years I used my heavy Rhino rear blade. One hour and less than satisfactory results. It just pulled dry gravel/dirt on top of rock hard gravel - no bonding what-so-ever.
This year I tried a different approach. LPGS with all seven scarifiers DOWN. Set about 1 1/2" to 2" below the two following blades.
My LORD - what a pleasant difference. It scarified the top 2" and the two following blades smoothed it out. It's now the the smoothest section on my driveway-smooth as a babies butt. Now the top is smooth and bonded with the gravel below.
Tomorrow I'll go down with the Taco Wagon and pack it down.
For those with rock hard driveways and are considering a LPGS. Get the scarifiers also. You too will be pleasantly surprised.
BTW - good that the Kubota weighs 10,100# and is 4WD. The LPGS with scarifiers down is a substantial pull.
/ My LPGS #2
My LPGS is 72 and has scarifiers...they make a huge difference. Only problem is that it can make the road flat flat flat,,No water runoff makes for quick return of potholes
/ My LPGS
Flat - for sure. However - I have this one spot that is, more or less, hopeless. I've built it up as much as possible. The water from the neighbor's fields, on both sides, just lies there saturating this section. It's been fixed for this year. I'm always looking for better material for this section.
Railroad ballast would be ideal and there is an abandoned RR line just a mile down the road. I've even asked - I think my name was put on a list. Just because I asked. And not the "good" list.
Oh, well - there is alway hope. It's been this way for 38+ years - I will survive.
/ My LPGS #4
OOSIK, You need some of this. 7000 lbs I picked up last week for part of my drive.
/ My LPGS #5
Question, can a crown be built into the gravel drive and the use a landplane half of the width of the drive and still keep the crown. ie, use the land plane on each half of the drive and not down the center? Just wondering. On my drive I can get it to crown, but I am using BX2230 with a 5ft rear blade. The landplane would need to be at most 5ft wide. But the drive has bumps and I can't seem to be rid of them. Thanks for the info. Jon
/ My LPGS
From my experience with my 7' LPGS. NO - you can not build a crown into a driveway with this unit. You CAN maintain the existing crown. Up one side - back down the other. The LPGS simply does not move material horizontally. It pulls material FORWARD and fills small voids, etc.
You need either a rear blade or box blade - something that WILL move material horizontally.
You need something with scarifiers to lessen the bumps. Loosen the top material - grade it back smooth. A LPGS with scarifiers will do this.
Crown & bumps are two completely different situations. Requiring two different implements.
A box blade with scarifiers might do this. But a set of scarifiers alone - followed by a rear blade would most effective.
At least in my case, the top couple inches must be loosened(scarifiers) - then this loosened material can be moved horizontally to create a crown. Loosening the top also bonds whatever you finally do to the soils below.
Like a pothole. Unless you first scarify - any soil added to fill the pothole will not bond to the soils below. It's like putting sand down on a cement slab. It just sits there and with traffic - it will slowly but surely be knocked out of the initial placement spot.
/ My LPGS #7
Why can't you build a crown with the LPGS? Does the Land Pride one not have adjustable shoes like the Woods one does? But even if it doesn't you can adjust the tilt of it with your 3 point links.
/ My LPGS #8
If I understand your question: Can you use a LPGS half the with of a crowned road to maintain the road w/o destroying the crown? The answer is yes - that is what I have done for the past 10 years with my 5' wide LPGS. We have deep frosts in the winter and spring mud seasons here which is hard on roads so I do have to recrown once in a while - every 3 years or so it seems but for routine maintenance the LPGS is all I need. I even run it down the center to remove the middle berm that is left. But when I do I lengthen the top link which raises the the front so the that blades just barely kiss off the berm. My blades a straight rather than angled so that is much easier for me to do.
gg
/ My LPGS #9
Your question is best answered in my opinion by explaining that while you can drive a 100 screws with a drill/driver, once you have used an impact driver, you will never do it again!
Different implements are designed for different types of work! Can you make another implement perform the task? Sure. But not as well!
Yes I can after lots and lots of effort cut out ruts with my straight blade, but not near as fast or as good as with my box blade with cutting scarifiers. However while I cut a crown on a driveway with my box blade, I again can use my straight blade tilted and angled and do it quicker
I have as of yet not acquired a land plane for my compact so I will refrain from commenting on its use. I have watched some videos, and think I would like to try one for routine maintenance of the driveway, but as yet no such process.
/ My LPGS #10
gg
You understood my question correctly. I built the crown by using my 4ft weighted disc (my scarifiers) and my 5 ft rear blade tipped via tilting the 3pt arms. If and when I buy a land plane, I would seriously look at one half the width of my drive. That would take out the bumps the drive has. Thanks, Jon
/ My LPGS #11
That's perfect Coy :laughing::thumbsup:
Can I use that one?
Think of a land plane as a long "box" blade. It's the length of the skids "footprint" that add's the magic, it basically cut's a material reservoir at each blade and deposits them where the long skids tell them to as it travels over your road. The long skid will basically average out the grade below it. Think road grader and it's looong wheel base with the blade hanging in the middle, the longer the wheel base the less reaction the cutting edge will have to road irregularities. A rear *blade or box blade are basically reacting to the tiny sliver of ground that it's riding on and usually any operator input is too much, too late.
You can crown a road with one in a similar manner as a box blade by altering the 3pt hitch arms or an adjustable skid shoe.
*a rear blade on an angle will have a decent "averaging" effect but none at "straight" or perpendicular to the travel.
/ My LPGS #12
Oosik how did you walk by those (up) scarifiers for 5 years without just a tiny bit of curiosity?:drink:
/ My LPGS
I have scarifiers on the LPGS & Bush Hog ROBB. I just thought they were for EXTREME cases. Come to find out - a whole lot of my cases must be extreme.
Example - my driveway has just enough silt, sand & volcanic ash, on top, to harden up and become concrete in the summer.
The Rhino rear blade is heavy enough - 1010# - to penetrate the driveway in the summer but is a real ***** trying to level/smooth things. The LPGS with scarifiers down will do a great job. The rear blade is my snow clearer and maintains the driveway ditches.
I have to be careful though. I have just enough small potholes in the driveway such that nobody wants to go fast. It's a mile long and straight as an arrow.
Convert the driveway back to "pool table" smooth and it becomes a drag track for some who visit. I have no trouble going 15 to 20 down the driveway. Some found it a challenge and said they could get up to 50 or 60. It was like a dust storm in the Sahara.
/ My LPGS #14
In the middle of summer the scarifiers will have a hard time digging in depending on your gravel. Right now is the ideal time. The top inch or so is dry and packed but once you get below that it's still wet around here. In a month it'll be like cement. I've added weight to my LP to help but often I just use the backhoe to loosen everything up.
/ My LPGS #15
:thumbsup:
I've never seen them on a blade. I'd like to have one like yours, just a little wider for angle width.
Hey I saw your pond again on the sunset thread. I remember you told me how deep it was, but forget the depth other than the water went all the way to the bottom and that was a very deep. Remind me for curiosity's sake.
/ My LPGS #17
Drill vs impact statement, I'll simply say ' I agree.' Especially if you're using Milwaukee's 12 fuel one.
However, to say that using a straight blade & a box blade to create a crown is easier and faster vs a land plane...I'll have to disagree. (Assuming I read what you wrote correctly and that's what you meant.)
I've had zero issues creating a crown on my drive, or creating 'half a crown' around the pole barn for drainage. Granted it could be my land plane weighs around 800# with the scarifiers in it and has 1.5" of tilt adjustment in the LPGS shoes. Add in the 6" or so I can adjust the 3 point tilt on the Kioti.
My box blade does a great job at moving materials from point a to point b. And for back filling trenches (septic finger runs & water/electrical trenches from house to barn.) But the LPGS did a remarkable job at actually leveling everything out with regards to smoothness.
As for your driveway maintenance comment, the LPGS is great at that. Can literally just drop it and drag. Couple passes down each side and all the potholes are gone, low spots are filled in. Does a great job on the gravel road I live on as well. Let's me fix it before the county comes out and turns it into a mudhole.
/ My LPGS #18
I have lots of rain and lots of elevation so crown and slope are critical. All maintained beautifully with a land plane. Have heavy blade and box blade sitting idle.
While moving material is important and capable by several different pieces of equipment. The land plane does it a little different. It classifies the material, fines and aggregate better. This allows for better compaction. Better compaction is harder, wears better and last longer. While there is more science and engineering involved above my understanding, I can appreciate the results.
An analogy may be;
You dig for gold with shovel and mattock ( grader and box blades). You find gold in the pan or classifier (land plane).
Beware there are many different land plane designs. Results may vary.
/ My LPGS
Did it again. Answered your ? three days ago and forgot to click reply - rustyiron. The little lake is 80 feet deep - five acres of open water - five acres of cattails. Hey - it's been all sunshine and up to 58F today. Mayhaps - spring IS on its way.
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
1988 Mack R688ST (A62679)
1988 Mack R688ST...
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
Two (2) John Deere 5000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
